Contact Methods
Website URL
http://
Gender
Location
Kennet & Avon
Occupation
Boater
Boat Name
Salix Alba
Boat Location
Kennet & Avon
3,714 profile views
J R's Achievements
Community Regular (6/12)
7
From memory, when we had our boat built (Colecraft shell) they 'blacked' the water tank with something that I cannot remember, that is designed for the tank. Its not the blacking on the hull. We also use a Brita filter jug for our drinking water. Never had a rust issue thankfully. Our tank (150 gallons) is in the bow and there is a plate/hatch that can be removed to look at the interior.
It is easy, with correct wireing and fuses etc, to bypass the inverter charger so that you can access shore power without going through the inverter etc. This is normal practice for new builds unless there has been a cost cutting exercise for what ever reason. It is also easy and cheap to retro fit this. Make sure that there is the correct fuse board and RCB.
I would be appalled if when buying a boat that I was not able to do a test cruise. What, if anything, do the brokers/sellers have to loose? Narrowboats may look similar, but they handle in different ways and you need to know that the handeling suits you for instance. If you don't get to do a 'test drive' walk away. In any event, before buying get a survey. Good luck with your search.
Not knowing the houseing of your battery box, 110 ahr & 135's are of different physical sizes, so make sure if you go down that route that they can be safely fixed. 110,s are cheaper to buy. In your question it is 6 of one and 2 threes of the other. Makes no difference, but do an electrical usage audit to make sure you have enough for your needs.
It is our experience that the person on the end of the that the person phone does not know didly squat about the boats that you be enquireing on. They are only there to answer calls and generate money for the hire companies. Best way to find out if the boat is up to your expectations is to phone the base where the boat is, who should give you all the info that you require; you are the customer after all. The hire company should give all the relevent information on their website, but this is not always the case sadly. The public, imo, are sometimes sadly duped into their expectations for the hire boat experience and receive an experience that is woefully below standard. There are also hire boat companies that also exceed the standards that we would like for our hard earned cash for our holidays.
Ant (oin) & Dec (ceis) ?
We replaced our Webasto water/antifreeze this year with a 50/50 mix. Have heard a 25% antifreeze mix will work but have not tried it. Never add/top up with a different colour antifreeze as mentioned above. When you do a drain down and refill there will be air trapped inside the system. Its a devil to get out and demands a certain amount of runnning the system, bleeding valves and topping up the header tank. It is not caused by the water mix added, just trapped air in the pipes. Any thing added must be well pre mixed. Adding the antifreeze and then water will cause problems with the circulation. We change ours every couple of years to be on the safe side and get the anti freeze from the local motor factors as its saves a lot from buying from a high street out let or petrol station.
All very well disolving the snail, but what about its shell? Seriosly though, try soda crystals and hot water. Will shift grease, soap etc very effectivly. (Untried on small squishy animals, but worth a go).
Its not a stupid question at all. As far as I am aware, regular diesel from the local forecourt is the same as red diesel in composition, except red has the 'excise' dye added to it to show that it is sold at a different tax rate to the white stuff. Its all low sulphur and about 5% bio. The rules changed a couple of years ago or so due to EU regulations. Red & white can be happily mixed. Obviously if you buy from the forecourt you will be charged the full vehicle rate; not good for the pocket but no harm for the engine. As we are now in the middle of a cold period, forecourt refinery suppliers put some sort of agent in the diesel to stop it from going into a treacle like state when frozen, therefore not flowing enough to work in a car engine. White diesel is not a bad idea on a boat in this respect during a prolonged period of freezing weather. We have used red & white mixed in the past with no problems.
- 29 replies
Is 805 AMPs enough to run 240 v fridge & 240 v freezer
J R replied to luggsy's topic in Boat Equipment
A new battery should never be added to an 'old' battery bank as this will cause problems. Suggest you use a drop tester on each battery to see if there is one that is faulty. If you have wet open batteries, make sure that the electrolite is up to the correct level. -
Its worth noting that when the final coat is painted it will take time to cure, depending on ambiant temperature. It will 'mellow' over a period (of sometimes months) to the final actual colour. This is based on experience with International paint. Look at lots of boats, and see what floats yours colour scheme wise.
Difficult to give some sort of figure without seeing the boat, but it would run to a number of thousands of pounds, depending on finish and materials involved as well as if the windows and mushroom vents etc are removed etc. To have it professionally done would also require it to be under cover, so cost of a dry dock would be an additional expense. Think in your case, if you buy the boat, concentrate on the things that make the boat work and function properly plus bring any lapsed maintenence work up to date if necessary. The 'pretty' side can be done in the future. There is no reason that you cannot learn to do the job yourself if the T Cut and polish does not work out to your satisfaction. I would suggest that it is one of the pleasurable sidelines of having a boat. Plus you would save money. Just to add, all our signwriting and coach lines are done in cut vynal similar to vans & lorrys. We did have it done professionaly and it was worth while the relative cost.
I must admit that I am not a great fan of Victron based on the failure rates, in various forms, of the equipment on hire boats, and private boats, from experence. I would however agree with above comments above on having some sort of built in redundancy. Have positive experience of Mastervolt products and would choose them over Victron. We went down the route some years ago, having done much research on available options, on fitting Sterling units which are seperates for each function. They have performed faultlessly over the last 8 years and work well for us. Everyone will have their opinion on the various choices and all three are reptutable companies. Cost is also an issue when it comes down to it. I would add that when getting an inverter, always go for pure sine wave, not quasi sine wave. 220v stuff is designed for pure sine wave and may malfunction or break if used with the quasi version.
It never ceases to disappoint me the thefts from boats from obviously some other boaters. A recent example was the Anglo Welsh hire boat that went down in the Widcombe flight in Bath. Bearing in mind that the boat was stranded on its side in the lock and at various times flooded, the booze, 4 x 13 kgs of propane and 5 12v batteries were looted to name but a few bits and pieces. A dangerous exercise I would suggest, but someone thought it was worth the risk.
