nb celestine
nb celestine last won the day on September 21 2012
nb celestine had the most liked content!
1 Follower
About nb celestine
  • Birthday 27/06/1961
    Cornwall
  • Interests
    Drink, Newcastle United, Wildlife, Golf, Fishing, Did I mention drink,
  • Occupation
    builder
  • Boat Name
    celestine
  • Boat Location
    devizes
5,410 profile views
nb celestine's Achievements
Collaborator
Collaborator (5/12)
22
  7. Just watched the video. I was wrong, I thought the magnets were on the coil not the flywheel. Thanks for the replies. I wish my saw was as clean as that one.
  8. Hello, I bought a well used Maculloch chainsaw years ago for £40 as I was only going to use it every few months or so. It's done ok, but now it starts after a while but cuts out after a few log cuts. I don't want to spend a fortune servicing it, as I'm thinking of getting a new Stihl if this one has had it. So, I've put a new plug in, new correct ratio fuel, and I'm just about to buy a new coil and fuel filter for it. So I want to know, when I replace the coil, do I push the magnets tight against the drum or do I leave a very slight gap? I think when I removed the old coil, it was tight against the drum but I'm not sure. I did think of taking the carb off and checking the membrane but I'm a bit fingers and thumbs so thought better of it.
  9. Evening, it's a few years since I've posted on here, and I've sold my boat now but always browse and this problem rings a bell with me. About 2012 I was, I think on the Wenford Arm crawling towards the end, when my engine sounded like I'd cruised over a Tesco trolley. An awful grinding metallic noise so I shut the engine off and checked the prop. Nothing. Came on Canalworld for advice. Told to check around the Skeg. Nothing. I informed everyone that I couldn't even turn the prop shaft in neutral with a pair of stilsons. Told that the gearbox was then the likely cause. So after a while I started pumping more and more grease into the stern gland and gradually, using the stilsons, it freed itself. I was told by another boater, who had a similar problem that he had a lot of grit between his prop and stern tube. Worth a go I suppose before the gearbox gets dismantled.
  10. The cars not bad Sam. 150,000 miles. Mot due September. It's a handy car for my building tools, springer spaniel, and stuff like that. Just had a alternator priced at £150 inc vat but going to get my sons mate to plug his gizmo in to see if there is damage to the electronics. If it's bad news, I'll be looking for second hand A4.
  11. Hi, just been out to check and my battery showed 11.9v before starting. After starting with no load it's showing 11.4v. Belt seems fine. I hope it's just a case of a new alternator. You're right Sam, I may have to scrap it which is easy, it's finding a few grand for a half decent replacement which is the hard bit.
  12. Thanks for the replies. The car is a 2005 Passat estate. A mate of my sons is a mechanic and has one of those iPad things that plugs into the car and has offered to pop up next week if I need him. I'll try the various suggestions though and I may learn something. Thanks again.
  13. Sorry if this is posted in the wrong place. For the last couple of weeks my headlights have been pulsing slightly, about 2 pulses a second. I'm assuming it's the alternator. Coming back from my special lady friends house about 2 hours ago I was accelerating up a hill when I heard a bleap and all my headlights went off. I pulled to the side of the road and found out that my sidelights and tail lights were still working so tried to limp the six miles home through the Cornish countryside. After a mile or so I tried the high beam and it worked so I travelled back through the lanes so as not to blind anyone. After a few minutes various warning lights came on the dashboard but those and other dashboard lights were getting dimmer. So I'm asking is it just a case of putting a multimeter on the battery tomorrow when the engines running and see if it's showing about 14.4. And any idea why it looks like both dipped beams have blown when the high beams are ok? Again apologises if this is in the wrong place.
  14. I bought a trail camera a couple of years ago. It's a Bushnell HD. It's used regularly on wildlife programmes as it has a quick shutter speed and a long battery life. The first one I bought, from the USA, developed a fault on the sensor but Bushnell in the Uk said send it back to their headquarters in Surrey and they would replace it. They did with a top of the range model that has black led,s that don't spook wildlife. I'm always worried in case someone finds it but I live in a quiet area in Cornwall. Be careful where you set it up because if a branch or plant waves about in the wind in front of the camera you will have a couple of hundred shots of nothing. They are exciting though. I had a video last year of a pair of ears poking above some ferns behind my back fence. For a split second, I thought it was a kangaroo until a deer popped its head up.
