blodger
Contact Methods
Website URL
http://
Location
Macclesfield
Occupation
Retired Merchant Navy
Boat Name
Rose of Tralee
Boat Location
Macclesfield
5,914 profile views
blodger's Achievements
Rising Star (8/12)
22
I do not know when and whence came the offer of a free mooring but doubt that would have fitted "Maggie"s aims. Maggie was not 'under the mental health services' and would resent it being implied she was mental sufficient to warrant the attention of mental health services. Concerned parties had engaged with mental health services exploring possibilities and they in turn had also spoken with/assessed Maggie. Maggie continued to pursue her own aims and objectives and endeavoured to use the legal system to fulfil them
I have a LPWS3 and I average a litre/hour on the canals and this only doubles when on the river running flat out. So I would not worry too much.
Re-opened this thread to say that after fairly lengthy litigation the boat referred to above was moved by CART yesterday.
Perhaps you could drop the voltage a bit with a heavy duty diode to avoid messing with the genny?
Really stoopid questions about tablets and internet connection
blodger replied to Starcoaster's topic in Boat Equipment
Your current Thee dongle/sim on PAYG should work most tablets. They often have only one mini or micro usb port to accept the dongle/keyboard/whatever necessitating the matching usb (OTG) cable to connect. Picture Information Free P&P Image not available Photos not available for this variation Have one to sell? Sell it yourself 7" Android 4.2 Dual -Core Capacitive Touch Screen 4GB Dual Camera Tablet PC Wifi | Add to Watch list Seller information daditong-eb (8939 ) 98.9% Positive Feedback Save this seller See other items Visit Shop: daditongworld Item condition: New Price: £39.88 Free P&P Buy it now Buy only this item (without additional items) Add to basket (purchase all items)Add to list Start of add to list layer Add to Watch list Add to Wish list Add to a new list End of add to list layer Cancel -
IMO you are best of trying a Three Data (Mobile) sim off Ebay; About 12 squid for 3gb that lasts 90 days. A second hand dongle can be picked up for a tenner As has been said many tablets will have the built in ability to use 3G direct from a dongle; Even the 40 squid chinese ones -
3G Mobile Wireless Router Broadband Power WiFi Hotspot Po... Member ID hkpowerstore | Feedback score of 130711 | 98.8% Quantity available: 19 -- US $13.59 £8.46 Buy it now Free P&P 28d 10h Buy it now Visit seller's Shop More actions If you want cheap this works with most dongles I have tried to create a hotspot which will run 5 devices -
The 3 pot is about 27hp with the 4 being the 36 IIRC. An old BMC1500 always seemed gutsier to me than this Lister. I have a 1990 TT Marine 57' with a 3 pot in it still going strong. Strangely that used to readily overheat. I fitted a header tank, dropped skin tank feed pipes into the (wet) bilge and stuck a radiator in series with the calorifier to keep engine temperature down. When the calorifier had to be replaced I fitted a much bigger one and overheating became a thing of the past. I use the boat much less now owing to the wife's health and I have the opposite problem now that of having difficulty getting the engine up to 80C working temperature. If a Lister did not smoke a bit now and then one would worry something was awry. Regular oil/filter changes are what Listers thrive on and vice versa. You seem to have asked your surveyor to find fault with the engine so he dutifully has. I doubt it is as bad as being unuseable and improvable. Try to get a good reduction in price on the strength of the report and possibility of need to replace the engine by all means but then give it a go.
My miracle 12 year old Lumax leisure Batteries.
blodger replied to Capt.Golightly's topic in Boat Equipment
I have some still going at 10 years plus that probably have only half their capacity but suffice so it is not beyond the realms of possibility -
There you are easy peasy The batts now they are better connected will drag down the alternator voltage but they should slowly rise to the alternator regulated voltage which you want to be at least 14.2/14.4v, Eve 40 amps is a fair old load on a belt so it is bound to slip; they do not always squeal their plight. So it is bound to be having a detrimental effect; its being slack that is.
Well they are spec'd for 60a so should be good for 40a. Replacements are 12/15 squid IIRC. Personally I would pay a bit more and get a 100/140 amp one ready for when you upgrade the alternator. (I am sure you will have to in time )
A diode would be bigger than most relays with fins for cooling and no need for the two thinner wires. My guess is that due to the small 40a alternator this is an inadequate type car relay or a lucas more suited to heater plugs than split charging.
It may be a significant contributory factor. I also suspect one of your batterries/charging regime. The box with wires is in all probability your split charge relay with the two thin wires being what actuates it when the ignition is on and the alternator is running. The two thick positives will be a live from/to the alternator to the starter battery and live to the domestics. Relays should not drop 0.8v so if cleaning terminals and retightening does not work it may be a case of replacing. If you have a means to jump the two lives thus cutting out the relay you should see the higher voltage at the batts proving the need to replace; Perhaps the contacts internally are burning out/corroded. In all probability it is your split charge relay with the thinner wires being what actuates it from the ignition being on and the alternator running respectively. The lives will effectively be one from the starter battery & alternator and one from the domestics if your starter battery is getting alternator voltage. Relays should not drop 0.8v so if cleaning terminals, refitting and tightening does not improve things it is replacement time. The contacts are possible burning out/corroded. Small Lucas relays are notoriously short lived. If you have the means to jump the two big terminals at the relay or remove and bolt together you should see the higher voltage at the domestics. Be aware that in doing so you are joining (parallelling) the domestics with the starter battery. ETA Two posts here as first disappeared; Slightly different content so leaving alone. CWDF seems very slow today
You cannot get a SOC indication by voltage when the batts are in use or charging or have recently been so. After prolonged charging the voltage at the alternator should more or less equal the voltage at the batteries and effective charging may have ceased. However, getting the last 10% of charge in takes up to four times longer than the charging getting them to 90%. The large difference in voltage at your batts compared with that at the alternator implies some problem of resistance on the route of the current to the batts such as bad connections or a dodgy isolator switch. Think about it, its the same piece of wire with different voltages at each end. However, a totally goosed battery will drag down the voltage at the receiving end. You need a good 14v + voltage at the batts to get maximum charging at the batts to use running the engine efficiently which is where so called 'battery boilers' come in to obviate 1/2 volt drops in voltage which come in if you are using a diode to separate engine and domestics as opposed to relay split charging. Hope that helps. It is not as simple as yes or No to some questions
Watch the charging voltage from start of engine running to when it stabilises and/or you switch off. It should gradually rise to over 14v. If it does not I would suspect the alternator charge voltage is too low providing charging is lengthy enough and the batts are not totally goosed.
