pquinn
2 Followers
Contact Methods
  • Website URL
    http://
    ireland
  • Interests
    music boating food
  • Boat Location
    ireland
7,637 profile views
pquinn's Achievements
Rising Star
Rising Star (8/12)
85
  1. Hello Folks, Any idea where I could find one of those brass plaques that people put in their bathrooms along the lines of "If you haven't eaten it or you haven't drank it, don't put it in here"? Thanks, Paul.
  2. No, i dont think so as i asked leesan the best way to cut the hole and they said a hole saw.
  3. What else would i be doing on a saturday night after x factor?
  4. Hi folks, I am fitting a toilet waste holding tank and am gettuing one of those toilet tank packages from leesan. The tank will be a ''rotary molded tank' which i assume is some kind of plastic/fiberglass. what i would like to know is if it would be a good idea to use a jig saw to cut the inspection hatch as i need to buy at least five different holesaws for the installation and will have little or no use for these hole saws after i have installed the toilet and tank. the inspection hatch needs a 121 mm hole saw. Any ideas for cutting down on all these hole saws would be welcome. Thanks . Paul.
  5. landline, invertor, travelpower?. Ours is not a liverpool boat but much the same and this is our setup.
  7. Not to hijack your thread EssBee but....... does anybody know of a good [solvent?] way to soften up the adhesive that holds them on, as far as i can tell mine were stuck on with something like marine flex/sika flex, or any tips would be appreciated. cheers, Paul.
  8. Oh! there not so bad, once you get to know them.
  13. Check the dimensions. Width wise i believe it is from under the gunnel to under the gunnel but i am sure somebody will be along to explain the easiest/quickest way to do this.
