Where do i start ... well i recently did an oil filter/oil change on my BMC 1.5 , simple enough you would think?! (with a little help from the oil filter thread) everything seemed to go well ..ok i had knocked the engine temp gauge wire but shouldnt have caused to many problems.
I went to turn her over and there was a click from the starter motor and a bit of smoke from behind the control panel. Ok i had the engine running just before the oil change and was fine .
RCR came out and apart from the seemingly obvious the starter was sticking or kaput,but they couldnt work out the problem with the wiring as it kept burning out and advised i get a sparky in.
Thing is everything was fine before the oil change... coincidence?
Regards
Ollie
