Wrinkley
Contact Methods
Website URL
http://
Gender
Location
CC ing
4,175 profile views
Wrinkley's Achievements
Community Regular (6/12)
5
Need some help with my Mastervolt Ultra please. How can I perform a factory reset on this unit? I have the mastervolt software to adjust the settings but cannot see how to reset to the factory defaults and did not take a note before fiddling! The unit works fine until I use the 'user defined' charge setting when the voltages are different to what I set.
Bit more info - water still running down the locks at 08:00. Moved along the summit and the levels are topping the side weir about 1/2 mile along. So if the paddles where closed the water would be still waisted. There must be an explanation for this action. Just can't think of one.
This is Foxton this evening 20:34hrs. The flight was locked at 16:00hrs as restricted boat movement times still in operation, supposedly to assist with back pumping. If there is a need to run water down towards the Soar could they not extend boat movement times to the benifit of all?
Canal & River Trust publishes 'Boater Report'
Wrinkley replied to Ray T's topic in Waterways News & Press
No mention of the income from fishing? Is it that insignificant? -
Take the original dip stick out and lay it on toilet tissue, dah-dar, you can see the oil!
Speed at tick over is OK. I don't get shouted at by folks or is that I only pass boats that are tied up correctly ? I have been in two minds for some years now. The boat behaves its self really well on the canals. Goes, stops, reverses all with out a fuss. In that wonderful, quiet, controlled way that a Gardner 2LW should. Its just that on the occasional times we venture out on the tidal bits I feel I could do with a bit more power. It's like going up a hill on a cycle in top gear, you drop it down one and go up easy. The engine never produces black smoke and never has done. You can wind it up from tick over to max quickly and not a hint of smoke.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Just for fun I down loaded rpm app that works on audio (apparently) and it worked! Would only measure 500rpm and above so no good for tick over but the readout was very close to the other two methods I have. This confirms, to me, that my engine will not turn the current prop above 950 engine rpm. But entertaining finding out.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
No, not from the leak off pipes the over fill pipe from the top of the secondary fuel filter. This, apparently, is to ensure adequate fuel available to the injector pump.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Oooo that's a good idea. But then I'm not on mains at the moment. Could measure the hz of my mastervolt.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Thanks for the link. For a tenner it's got to be worth it. Just as an aside, how do you know the new one is accurate and your original one faulty? ?
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Both belts run from the engine pulley to the alternator pulley, they run in parallel. The cycle rev counter sensor is mounted on the inside of the engine pulley. The frequency counter is used on the one phase of the alternator stator winding. The engine to alternator pulley ratio is 3:1.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Apologies Boater Sam for not replying earlier. I don't think that belt slip is a big issue with my set up. I have two 13.5mm belts on the alternator. The readings from both ways I have of measuring rpm do not differ significantly from each other whether the output from the alternator is 20 or 120amps. I would have thought that if belt slip was occurring the difference between the 'rev counters' as the load on the alternator increased would change. I am reasonable sure that most of the claimed 28 horses in 1953 for my engine are still at home and available.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Understand what you are suggesting but if two separate systems to measure revs that I'm using are roughly in line why would a third be different?
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Thanks for you comments, I'll try and go through them. Exhaust is just about clear on full throttle, had a bmc 1800 before and that gave black smoke on full wack. I have no way to measure fuel usage other than the average use between tank refills is constant over the eight years from "new". On full throttle there is still fuel running back to the tank indicating, to me, plenty of fuel available to the pump. Rev counter is a cycle speedo fitted to the engine belt pulley which matches the alternator hz output. Sounds a bit rubbish but it works well. Tick over 400rmp, flat out just over 1200, the plate on the injector pump says max 1300. The prop I have is bent and needs repairing just trying to work out what to have it set to. My thinking is 22 x 21. The 22 x 22 is fine on the canals I would just like a bit more power/revs on the occasional river and tidal bits we use.
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
Well tried that "the fuel rack "slider bar" is moving fully to the right and is up against the fuel limiting trigger at full load. I.e with the engine at full load, try and pull the the fuel rack outwards, to your right. " so still thinking the load is too much for the power produced. More power or reduced load. As the prop needs attention got to try and have adjusted to less than the 22 x 22 it's supposed to be. Any body got a 22 x 20 1.5 laying about I could have a go with?
- 52 replies
- 2lw
- norton canes
(and 1 more)
Tagged with:
