Bargebuilder
Days Won
5
Bargebuilder last won the day on August 1 2021
Bargebuilder had the most liked content!
Gender
Location
Leicestershire
Occupation
retired
Boat Name
Dipper
Boat Location
Wigan
Bargebuilder's Achievements
Rising Star (8/12)
405
Remote control for bow truster
Bargebuilder replied to Ian LAMBLEY's topic in Boat Building & Maintenance
Especially since most narrow boat thruster tubes aren't formed with the correct edge radius where they penetrate the hull. Most tubes also don't terminate perpendicular to the length of the boat, instead terminate to follow the line of the hull. Some even have grills over the ends of the tubes. Between these three, a large proportion of the advertised thrust is lost. The picture is of a thruster tube correctly installed for maximum thrust on a grp boat, but I've seen similar work done on a steel replica Dutch barge. -
Especially a variable speed one. -
Rust patches or microbial / MIC?
Bargebuilder replied to Jamesl9's topic in Boat Building & Maintenance
Many, in fact probably most boatyards don't even offer the very best steel coatings, those that are used for power station cooling water inlets, tanker ballast tanks, oil rigs and of course the Forth Bridge, maybe because such coatings are designed to offer 25 years of protection in aggressive salt water environments; not good for business perhaps. -
Bargebuilder started following Where can I go with a 9' beam? , Rust patches or microbial / MIC? and Remote control for bow truster
This Chemco coating provides a degree of protection against MIC according to the manufacturer. It was applied to all underwater areas of my boat 14 years ago and shows no signs of failure anywhere. It is said to last for 25 years and it looks like this is a very reasonable claim based on performance to date. It is highly surface tolerant and water tolerant during application and can be infinitely overcoated with minimal preparation when those inevitable scratches and scrapes occur. Might be worth a look for anyone concerned about MIC. Solvent-free Wet tolerant – Can be applied on soaking wet surfaces Excellent chemical resistance and abrasion properties Glassflake-reinforced for added protection Can be applied in any environmental condition No operational shutdown; nearby work can continue without disruption 100% solid / Zero VOC NSF certified for potable water applications User-friendly with high flexibility and ease of application No recoating limitations No humidity or dew point restrictions Health & Safety risk and Fire Hazard significantly reduced Quick back-in-service times APPLICATION AREAS RA 500M is fully compatible with all methods of surface preparation (abrasive blasting; water jetting; mechanical) and has been extensively used for almost all vessel areas: All Tank internals Pipework (internal/external) Decks (internal/external) Accommodation Blocks Underwater Areas -
I have two of them on different boats for many years and they have proved to be 100% reliable. I have also recommended their use to sailing friends who have also fitted them, been delighted and saved a fortune. One of my friends who has one on his yacht is currently sailing around Iceland, and he isn't concerned about reliability! But if you want to pay original manufacturers prices then that's fine too. -
Anyone who's bought a manufacturers own, or specific marine radio controlled thruster switch has wasted hundreds of pounds. I paid a bit over £10 for mine and it works a treat. I can even operate the thruster from the bank to draw the bow closer. On my lumpy water boat, I've used one of these to control both my bow thruster and my anchor windlass remotely. Easy to fit and has proved reliable for at least 6 years. -
I'm not well informed enough to contradict this statement, but this is text taken from the CPD certification website: "LFP batteries are often portrayed as a safer battery technology. You can find false information, stating that LFP batteries do not burn and some sources even state LFP batteries cannot go into thermal runaway. LFP batteries tend to produce less gas during thermal runaway, which makes them safer in some way, but LFP batteries can go into thermal runaway, they can burn, and there are reported cases of Li-ion battery fires with LFP batteries." Perhaps CPD are wrong, but it could be such information that the insurance companies are using.
Which was why I was careful to write lithium and not specifically lfp. However, I was interested enough to 'google' the subject and several websites make comments along these lines: " Can LiFePO4 Batteries Get Wet? The answer is nuanced. LiFePO4 batteries can endure a certain degree of humidity and splashes, but submersion or prolonged exposure to water can be detrimental. Here’s why: Corrosion: Water can lead to corrosion of the metallic parts inside the battery. Corrosion affects the battery’s ability to conduct electricity, diminishing performance and potentially causing the battery to fail. Short Circuits: When water infiltrates the battery, it can create a path for electricity to flow uncontrollably, leading to short circuits. This not only damages the battery but also poses a safety risk. Chemical Reactions: The electrolyte in LiFePO4 batteries reacts adversely with water, potentially generating heat and gas, which can be hazardous."
On that occasion, there was no damage to a third party, but had there been a fuel spill, I very much doubt that they would have paid the fines. If a lithium battery were to have got wet, shorted and caused a fire that spread to surrounding boats, I doubt that they would cover those 3rd party claims either.
Even if the boat owner has no idea that they have been negligent and is convinced that they have taken all reasonable precautions. I know a couple that own a wide beam that perforated at the waterline. By the time it was noticed the boat was sinking. Once craned out and examined by the insurer, they refused to pay out stating that there were insufficient anodes.
The concerns may be, rightly or wrongly, that the above dangers can be almost eliminated by certain actions by the boats owner/crew, whereas there are reports of modern electric vehicles spontaneously combusting whilst sitting on the driveway, not even on charge, and in no way avoidable by the owner.
I can only speak from personal experience, having crossed both The Wash and navigated the tidal Severn from Sharpness to Portishead and then up to Bristol in my NB. On neither trip did I take a pilot or follow another boat and neither trip was particularly demanding in terms of navigation. Of the two, I found the Severn to be the most straightforward because the navigation marks are superb, with leading marks that are unmistakable. It's important that in both cases you do all the 'homework' and it's essential that the weather is calm and forecast to stay that way all day in the case of The Wash, and for a few hours in the case of the Severn. The boat must be prepared for lumpy conditions, vents taped up, fuel tank checked for sludge, a new fuel filter and several spares etc. I used and would highly recommend the use of the Navionics App, download to a phone and tablet so you have a backup. It shows you exactly where you are and where the shallow bits are and makes either voyage easily doable without a pilot. I have done some coastal sailing, so I wasn't put off by those who talk of sea monsters and other terrors, and we were rewarded with trips that were both memorable and great fun. In fact, we may do the Severn again next year.
