Jac H.
New Member
Jac H.'s Achievements
Gongoozler
Gongoozler (1/12)
0
  1. I just happen to have a 1500 watt and a 200 watt inverter and the 1500 watt wont not blow its breaker when trying to use it alone, my now X-Wife bought a 200 watt inverter yep a cigarette Lighter one, when we needed an inverter years ago, the 1500 watt handled that job very well, but I had ordered that 1500 watt 10 days before she came home with that micro inverter all proud, I asked her what she was going to do with that light farts, LOL i doubt it would do that, anyway since the Divorce I have wound up with both of these 2 inverters & my 2 daughters are both rather tech happy, anyway i have found what they are needing to power uses 1650 watts which I know the 1500 wont do alone is it possible for me to somehow merge the outlets from the 2 inverters I will attack a pair of plugs and block the extra sockets and have the 2 cords merge in 1 plastic power box with a switch, and I will have a set of very High grade Copper or Brass Spring Clips to connect the par of inverters to the Battery, yes I will probably have to get inside that Micro inverter and attach a real wire to its power input, & modify its exterior power connection hole to accept what I am thinking of using is a section of battery Cable for any vehicle or boat, versus its cigarett lighter plug since my opinion of those is if they work your damn Lucky if it doesnt melt your vehicles wireing. LOL any Helpful ideas will be greatly appreciated, I guess if worse comes to worse I could just buy them a 2500 watt inverter, which might be really nice hooked up with the 1500 watt one if combining them will work I am unsure so I figured I would ask at the place with the best info I could find about inverters which happens to be this site, regardless I will have them a minimum of 2 if not 4 Big Powerful Batteries, any suggestions on the Battery Choice would be greatly apprecieated also, I am unsure if I should consider Tractor Trailer 6 volt Batteries connected in parallel to get my 12 volts or just multiple 12 Volt Recreational Vehicle Batteries, I seem to remember someone saying years ago using 2 Big Rig Batteries connected properly would provide more Watts over a longer time, but that was around age 12 so 41 years ago. LOL Anyway my main Question for now is Can 2 Inverters Be Merged To deliver the Combined Wattage of the 2 Inverters since I have a 1500 watt and a 200 watt paperweight at best, I am sure many will say throw that thing away before it causes a problem that will cost more than just buying a 2500 watt inverter. Ha Ha
