Hello
According to my handbook the cavity required for the CG2200 is 465mm wide 460mm high and 5mm above floor and 500mm deep (these are the MINIMUM distances)
Again according to my handbook the oven itself is 472 mm high 495mm wide and 425mm deep and it is mounted "over" the cavity hence the difference in hieight and widt
Hope that helps obbut
N
My rev counter will not return to zero despite switching off the engine and all 12volt power. It is mounted in a the basic control panel fitted with my Lister LPWS4. It used to zero and it still moves up and down as the engine revs are varied. I have recently added enlarged my domestic battery bank and fitted a new starter battery I have also renewed failing crimped terminal connectors an the alternator. Please has anyone got any idea what may have gone wrong
Thanks
