Gender
Female
Location
Harrow
Occupation
Property Manager
Boat Name
Anonymous
Boat Location
Uxbidge
Simon and Pu's Achievements
Explorer (2/12)
0
Simon and Pu changed their profile photo
Help please. Oil spill and rattling engine
Simon and Pu replied to Simon and Pu's topic in New to Boating?
I'm very interested now in getting the oil pressure sorted. All red lights are out. And no beaping. I will make a video and upload -
Hi guys will take more photos to show you that cap. Sorry for no reply was cruising. The beeping has stopped. I Wiped everything that was sprayed with oil. I spent a good 3 hours cleaning everything before adding in the engine oil. Lucky my wife baught a mega pack of 30 tee towls, came in handy. Yes the leak was right next to the alternator. Now when I run the engine. I have 13.5 volts on both Gages. -
Sorry. I ran it low for a while then gave it a quick burst. Then I seen where the oil was coming out -
Ok all sorted. Got the oil. Screwed the screw back in. Moped out all the oil in the well deck. Added the oil. Dipstick reading bang on. Fired up the engine and gave it top revs. Then noticed oil farting out of a hole. Stopped engine. Then just under a big screw hole was a cap that has come off by the alternater. Hell knows how that came off. All back on. Fired up. Runs like a dream. Thanks for everybodies help today. Lol he's right -
There was a warning sound beep just started as I turned off the engine. Bilge ge pump is switched off. I 100 percent will not pump oil into the canal -
ok I'm going to be away for awhile as I'm going right now to the boat yard for 15/40 thanks all for your help. I'll be back to update -
The engine is Isuzu 35 inc 120d2 i can't see an oil pressure gage -
Ok great I'll walk to the boat yard and get engine oil should I not start the engine until I have oil ? So this is gear box fluid where does this go as I can't see any where for it. I can't find a dipstick for the gear box -
Good morning. Last night I came home and my wife was running the engine, she told me there's a funny sound. It wasn't funny it was terrible. She didn't turn the engine off and kept running it ( big mistake I know). This morning I've lifted the boards to find a long pin had come out and oil from the engine is spiller out all over the place. I have put the screw back in tight. And checked the oil dip stick and its bone dri please see pics below 1) is this the correct fluid to put in where the oil engine cap is you can see in pic 2 the pin that was loose making the terrible sound
Our cat has gone missing for 3 hours now, he has a tracker. I've explored all the area the tracker last seen him. When I went on the search there is a dead animal on the tow path. What is this animal? The same animal but a smaller one was close by looking at the dead body. I fear what got this creature also got our cat
Smoke poring out of top air vent on fire
Thanks everybody for your help. It's was blocked. And it's now working better then it's ever worked before. It's now like brand new -
We got to sleep and cleared the boat. This miring I removed the fire bricks inside there are all cracked and Brocken. Removed the plate and stuck the boat pole down the chimney. The fire place was half filled with soot. So I'm thinking it was very blocked. Off now to get new fire bricks. And re fit everything. And will try another fire. Will keep you posted. Thanks for all help
