umpire111
    United Kingdom
  • Occupation
    retired
4,436 profile views
umpire111's Achievements
Proficient
Proficient (7/12)
10
  1. can anyone tell me if this is suitable for use with AGM Batteries, cant seem to find reference to such in the manuals. On the unit is markeed for use with Lead Acid and li-ion batteries only but I ma assured by another boat user that it will be fine with AGMs. I have bought Rolls S12 240AGM RE batteries.
  2. Not sure and not at the boat, can’t recall any vent is in bay but suppose they’re must be
  3. Tx for all replies, considering all of them
  4. When away from the boat for a while I put on covers at the stern. Recently when returning I have found fungal growth on the board edges as per photo. Often a distinct mushroom shape. I know this is due to the warm dark air beneath the cover but am loathed to leave the cover off. Any idea how I can prevent this?
  5. Not sure it’s sited directly above the calorifier, it may be for the central heating that may explain why it didn’t drain
  6. think Im about to show my ignorance but here goes. Changed the coolant on my NB for first time today. All emptied except the white plactic header tank about the calorifier did not budge, should the coolant not have drained out of that as well? Im sure that feeds into the calorifier which I trust emptied. Put me out of my misery please
  7. Much appreciated…..not looking forward to doing it
  8. Understand, tx. May seem a daft question but I couldn’t just replace the 7 litres I e got out and repeat process more regularly?
  9. Tx, can’t get any pipe down the bleed valve. Tx for response but I think there’s quite a bit in both skin tanks I agree re drain valve! How did he get it out of the bilge?
  10. Have a Beta 43 in my NB. Tried to drain engine coolant for first time today in order to change it. I attached a plastic pipe to the outlet drain valve on the engine and dropped it down to a container in the bilge, removed cap on expansion tank on engine. Opened drain valve and it started to drain out albeit slowly. When there was about 7 litres in the container it stopped draining. By blowing down the plastic pipe it was evident I have drained all liquid above that level. Unfortunately the skin tanks are lower and there is still coolant in those. I removed the bleed not hoping to get a small pipe to the bottom of the tank and to use a small pump to remove the contents. The hole is about 3mm wide and not big enough to insert a effective pipe. The only way I can see to get the coolant out of the tanks is to remove the main inlet pipe at the bottom of the tank. I cannot get a container underneath it as it sits on the bilge bottom. I could ley the contents go into the bilge but that would mean I would have, estimated, 7/10 litres in the bilge form each of the 2 skin tanks. Am I missing a trick here?
  11. Tx for a very comprehensive and informative response, much appreciated
  12. Want to do this in 2 days, can anyone tell me suitable moorings for a 57ft NB please. Also are there plenty of visitor moorings in Sheffield Basin, are they safe? Any places to avoid mooring going to Sheffield?
  13. Seems dry in the connection don’t know what else can do
