Hi
I have flexible solar panels bolted to my roof.I know not the best idea but that's what i have.As sure as mustard my paintwork under them has cracked and blistered and flaked off.
Now how to solve this problem.I think the heat generated by the black panels has cracked the paint them moisture has caused the dreaded rust.
So i think mask off the panels remove the panels and remove the paint underneath.Feratan primer then a good paint like epiphanes multiforte.Or what do you guys think about wax oil or car under shield under the panels when refitted.Also just raise the panels by using a tap washer or simular.So moister can run out and have a small air gap.Obviously we won't stand on them.
Am i on the right track or do some of you knowledgeable guys have a better idea.Im going to stick with the panels i have.
