Can someone please explain the best way to remove all three of my ejectors from my engine so that I can get them checked over due to one of them is leaking a little fuel
thank you
May I thank everyone so far for there views and comments so far.
Some have stated what I was asking in my original question of other boat owners who have the same set up as mine in what is the best solution I could use for the safety of my boat and others
as in the pass other boat safety inspections have never picked up my boat for this important issue hence way I’m trying to understand for my safety as well as others so no one will get hurt
am all for the BSS and I do know the rules after being on the water 23 yrs but if you don’t ask i will never know what is right or wrong
Recently had a BSS done
i have a 50 Tug Narrowboat with gas lookers on both sides as you enter the boat from the bow
i can store 2 x 13kg gas bottles one in each
my questions are is there any other Tug Narrowboat with this set up and have you had any troubles with passing a boat safety test
Hi,
need help please in finding a speed control spring ( not the correct name for item) for my JS3M engine the one i have at the moment I feel is not the correct one and has stretch
Thank you all for the advice have sent the photos to Martyn of my engine
How much anti freeze does the JS3M hold please just the engine ?
Does any one have any photos pitctures of a cross section of the jp or js ?
I have flushed the engine and yes byeck you was right a lot of small peace of Rush was around the tape area using a vac got some of it out
Hi to all
As stated above I feel I have a little problem with over heating with my JS3M.
I see there some bleed point well I assumed they are bleed points on the engine its self
I have changed the antifreeze and tried to clear out some of the rust out of the expanction tank that possible may be some were around the engine its self
Am due to change my oil soon as I have done now approx 500 hrs now
However my main question is please what's the best way to get the air looks out.
Regards
Hi to all,
From what advice I have been given I thank you all
The question I have is when adjusting the pressure release value e in how many times do you turn it once you have undone the locking nut
Thank you again to all.
