goodboy
About goodboy
  • Birthday 26/10/1960
    onfa
goodboy's Achievements
Gongoozler
Gongoozler (1/12)
0
  1. It the fuse box for a eberspacher there should be a cover on top I have one just like it The relay coil is there to run a fan type heater like the one in a car
  2. If this switch is used for 12v the neon will never light Not enough voltage it made for 240 v
  3. Some older outboards have the oil filters inside the power head (engine) only modern outboards have a spin off filter cartridge I am not familiar with this outboard only Honda and Yamaha 4 strokes
  4. Thanks everyone for your input. I found bottles link very good .it seems people like what thay have at the moment and for good reasons. For me i think it will be the bmv700 or the NASA bm2 or merlin power gauge lite Similar features and price, I need to know amps in and amps out at any given time.
  5. hi all i'm thinking of buying a battery monitor either smartgauge / nasa / victron ect, what would you buy and why, what do you have and how do you like it,i would like the smartgauge but would like something that shows amps in and out. thanks team.
  6. Thank's kind and absent friends hope to see you all again soon
  7. The burner work's as long as you hold the knob down so flame Patten can be cheched
  8. thank all anyway I will find out this weekend if it passers the bss
  9. Fitted a 400 amp mega fuse between the battery's and the inverter
  10. I'm going to buy anew hob after xmas, this time i will have a smeg it/s better stainless steel and better quality I don't see the safety issue ( bottle ) when it will not stay lit on the small burner we never use anyway .
  11. one of the taps on my belling hob no longer stays alight the thermocouple gone me think's no it as a electrical connection to value in the gas tap never seen one before any way as it will not stay alight will it pass the bss like this or is it £30 for anew one
  12. removed the old leaking core plug from the cylinder block and fitted anew one replaced the antifreeze
  13. The cross-hatching is crucial for piston ring lubrication and bedding in of the rings on a new engine and the running in is now done at the factory on a test bed
