Mickj
PatronDonate to Canal World
    Midlands
  • Occupation
    Dogs Body
  • Boat Name
    Duke
  • Boat Location
    Around about
2,343 profile views
Mickj's Achievements
Contributor
Contributor (4/12)
  • Patron Rare
Recent Badges
0
  1. Change the fuel drain carb of old fuel
  2. I also had a problem with the bowthruster when first fitted the rubber inside was the wrong one it would work sometimes but labored the engine at any revs had to have a replacement after lots of hassle with ARS
  3. Hi, as I read it the OP's bowthruster is hydraulic. So is mine should have said that i guess
  4. Hi I have the same engine and bow thruster in my boat and have had the same problem, found it was the alternator a 75amp 24v when batterys bit low if you used the bow thruster at tick over revs dropped well down, the engine just has not got enough power at low revs to power prop. alternator and bowthuster a smaller pulley on alternator helped a bit
  5. take the wire of and try again?
  7. Bimble have 175w used monocrystalline panals for £65.00 37p per watt
  8. Bimble Solar www.bimblesolar
  9. R N Diesel 01902 450912 use them at work sound guys
  10. Look on Bimble solar recommend Black Tiger seal adheasive check there web site
  11. this looks the same? ebay 252458495096
  12. I think I may have seen this boat Sunday while moored at the anchor high offley heading towards market Drayton
  13. Move the rack on the pumps as above, you should be able to rig a stop cable up to do it for you
  14. That sounds like a great idea have started supping will see what happens!
