Schipper
Everything posted by Schipper
  3. I am thinking about the tunnel at the end of the Caldon ?
  5. Hi Dave, About 15 years ago,Mal Nicholson sailed from Hull to Rotterdam in his Humber Keel called Spider T. So it has been done!!
  6. Floggers ignore number 3 it will ruin your story.
  7. At the lock now,all is fine! Just 2 boats in front, going down. Geert
  8. Just been to this lock,repairs are done, waiting for the cement to dry. They are going to do a dummy run about 6 tonight,if successful, the flight will be open again. There is quite a backlog on the number 6 Lock!
  9. Latest I got,is opening again midday tomorrow ,hopefully Geert
  10. Do you mean the program where the winner left the cauliflower in the oven?? And still won.
  11. Now I seem to remember a mister Bond,doing a far better job then this driver!
  12. Try www.thinkauto.com they do remote filter kits. Geert
  14. I'm always keen to learn,how do I operate the drive plate?? I only got one cable from my selector going to the gearbox,selecting forward or reverse and one to the throttle. Is our boat missing a clutch padle??? Geert
  15. This box has twin conical clutches(forward/ reverse).When ours failed I was still able to use reverse. It seems a bit odd that they both failed at the same time?? Geert
  23. It is a black/grey water reservoir and pump,works with a float,does not clean the water.
