wiltshirewonderer
Everything posted by wiltshirewonderer
Mobile welder needed asap
wiltshirewonderer replied to Sam226's topic in Boat Building & Maintenance
Kev Kyte (marine welding) might be able to help. +447934851240 -
Magpads. Rubber encapsulated. Popular with my friends for such things (I work for this firm) https://www.guysmagnets.com/magnetic-products-c2/vehicle-mag-pad-1-p194
Unfortunately it's not. I've spoken to the owners in the past about the place (they brought it back from being a wreck). Lovely location if you can deal with it though.
Using high powered magnets on a canal boat
wiltshirewonderer replied to Eloisec93's topic in General Boating
Also what I use. To be fair though, I work for Guy (the seller on eBay) so it seemed daft to use anything else. They held the panels in 70mph+ gusts during the storms early in the year. -
Nearly New Boats, Snagging and Surveys
wiltshirewonderer replied to Blue Knight's topic in New to Boating?
Definitely not me! I'm a bloke and bald. I know who you are probably talking about though ?. No wondering for me at the moment, my current boats engine is in pieces whilst parts are sourced for a top end rebuild. -
I've been using 4 per panel on my 160w panels. Friends have used 6 on 250-300w ones. Same reasons I went for the magnet solution. No damage from water ingress affecting the paintwork after 18 months either which was the main downside risk as far as I was concerned.
I use these rubber coated magnets attached to 'L' brackets. About £24 for 10. https://www.guysmagnets.com/magnetic-products-c2/vehicle-mag-pad-1-p194
They used Omnia Clear on mine. It didn't seem to hold up well in exterior locations that were heavily exposed to the sun / UV. Bow doors were fine (I had a cratch cover) but the dog box needed redoing after a couple of years.
Removing bitumen
wiltshirewonderer replied to Arthur Marshall's topic in Boat Building & Maintenance
Have you tried a carbide blade paint scraper? I used something like this then a soak of paraffin & lots of rags for a similar job. Only downside is that the paraffin then needs thoroughly removing to stop paint adherence issues (I used a blowtorch and then multiple cycles of white spirit, detergent, water....) https://www.amazon.co.uk/Bahco-Carbide-Edged-Paint-Scraper/dp/B000288LP6 -
Resealing Caldwell's windows
wiltshirewonderer replied to tortuga guy's topic in Boat Building & Maintenance
Worked for me. Even sealed two leaks that had been present for years before I bought the boat (oak inner frame completely rotted out in two corners) - mine had an inset rubber bead to cover the screws and removing a bit at the top before applying liberally sealed whatever the source of ingress was. -
What's the worst you've had around the prop?
wiltshirewonderer replied to wandering snail's topic in General Boating
A mountain bike tied in a nice knot around the prop at county lock just after I arrived on the K&A. Moored up under the flyover, saw more than a couple of locals jacking up. Once we were free, I did some serious night cruising - think it was about 18 hours cruising between setting off at sunrise and mooring up for the night, thank god it was only autumn. -
Man threatens to blow up boat on canal
wiltshirewonderer replied to Sir Percy's topic in General Boating
Apologies for that, I was just very annoyed about myself and this boater being attacked for (as far as I could tell) no good reason. I shall try and stick to non swearword insults going forward. The good news is that CRT has finally decided to let the chap in question pay for the mooring he had with them and thus the boat removal is no longer an issue. He still has a police charge to deal with but TBH he is in a better place negotiating that than being homeless (especially given that the police appear to be on his side). Thankfully learned baton twirling hippies saved he day / his life. From what I've seen, it is another left hand vs right hand issue, no individual to blame at CRT but definitely broken processes. -
Winter mooring or CCing round bath area
wiltshirewonderer replied to Eloisec93's topic in Living Afloat
Its always crowded around Bath (on the canal part). Second busiest spot after London. -
Whilst I'm not a hippy spinning whatever the insult was (Nor part of the NBTA), I get out and help the boating community rather than just bash the keyboard on here. I have helped in well over a dozen situations similar to mine in the last year. That said, thee guy in the OP was only saved due to a member of the NBTA defusing the whole thing, he would have likely been homeless and/or shot otherwise. On Sunday, an OAP on a boat with NO HEATING due to issues outside of her control is getting a new burner fitted due to a few of us getting together and sorting things out in the real world. A normal weekend for us with low post counts..... EDIT: No need to respond, I'm in danger of doubling my post count tonight and I'd rather avoid that. -
No you aren't, but you still have to move the required range over the 12 month period of your license - winter mooring taken or not. You would have to be mentally retarded to think you had to move during the period that you have a mooring agreement that means that you don't have to move..... are you certain you haven't been drinking? -
Don't you remember the issue with me getting stuck in a lock that CRT had rebuilt several inches narrower? It was my fault despite the boat having been through dozens of times previously. I haven't previously discussed the issue on here but I bid on and won a mooring (Finger pontoon) that was advertised as supporting a 10 foot wide boat, which after having one commissioned as such and me turning up with it, only happened to only be 9 foot 6 inches wide (My fault obviously). I could add a long list of stories from others I have helped but I dont think its worth the effort. I'd rather not add you to the list (You don't know me on here but we have met in person a few times and have got on well) but happy to do so if you so wish. -
Another keyboard warrior then... Post count isn't everything. Some of us are out living in the real world trying to sort things out for fellow boaters. In terms of manners, the two of you really should take a look at your own posts on this thread and the default position and attitudes you have taken. Wishing you a good night, hope neither of you end up on the wrong side of CRT through no fault of your own. -
Oh ok, so you are just a troll. I'll just ignore you going forwards -
Apparently all is now well and the 'pigs' as you call the police that were in attendance are *really* not happy about what they got dragged into and are on side with the boater in question. Thinks its time for you to stop drinking and go to bed. -
Point your friends in the direction of http://barges.org/. Dutch barges are a different kettle of fish to narrowboats and specialised insurers recognise that.
If you are cc'ing you could bounce around Bath - BoA - Semington for the winter months and then make a point of getting good miles in (Bristol to Pewsey?) once it gets warmer. Not as easy as a winter mooring but on the flip side less costs and a regular change of view. If you took a winter mooring you would still need to get the miles in anyway. -
Yes he has and yes they have. -
I've been unlucky and have had two run-ins with CRT management through no fault of my own. The only way I survived them going into self protect mode was through keeping hold of my email communications, having 3rd parties record videos and having good contacts. I really do hope you never have to face similar situations. PS these records had nothing to do with movements (boats or otherwise), either for me or this chap. -
A lot more going on than is being publicised. Appears to me to be another CRT boat removal on very shaky grounds using police 'support'. Unfortunately I can't say more but thankfully the chap has kept good email and audio records. After a bit of external support to deescalate the situation, my understanding is that he and his dogs are now with the police and latter being spoilt. Its a shame more boaters wouldn't give a hand to those that look like they need a bit of support, rather than just spreading malicious gossip down the towpath telegraph. If they did, this wouldn't have happened.
