series3
Everything posted by series3
  1. No big deal. Just thought I might post it herr. I'm not asking for advice so keep it. I will not be catching it.
  2. It has been posted on other sites. They are building near the marina so it may have crossed the canal. I have 2 and don't need another.
  3. https://m.youtube.com/watch?v=ky2G-GX_094&feature=youtu.beLink to youtube. Been feeding it for a couple of days Plank lane lift bridge on Leigh arm of the L&L.
  4. Bunch of keys left in the pump out ststion at plank lane lift bridge. Leigh branch of L&L.
  5. I had a fabrication shop. Draw it on the back af a fag packet and take it in to one. They'll do the rest.
  6. Where are you? My son in law does them.
  7. I like it. Linework looks thick and uneven Though. I wouldn't let him near my skin.
  8. Any solicitor who deals with claims will do. It's a judge who understands you should hope for. If it's a complex case then I doubt there will be any "no win, no fee" solicitors, so expect to pay. County courts are not cheap if it goes to trial.
  9. I got 12 from PB. Fast turnaround times. Nice bloke and service.
  10. Nice to meet you too nightwatch. It's nice to put faces to names. Dave n Michelle
  11. Flashlight should be fine. You can see the other end of preston brook as you enter. It's a straight run. No bends as such. I'll be in the boat behind nightwatch. Just been through also. ...go through on the hour...about fifteen mins to exit other end. You'll be fine. Flashlight should be fine. You can see the other end of preston brook as you enter. It's a straight run. No bends as such. I'll be in the boat behind nightwatch. Just been through also. ...go through on the hour...about fifteen mins to exit other end. You'll be fine. No junior...no lights. Just a clock painted on a board
  12. We're on the way up to Chester too. Looks like it's going to be busy. Worsley at the moment.
  13. Cleans all the crap off the hull too.
  14. He had to fill a coupke of locks at the bottom of wigan. you will also...not fixed yet.
  15. I take it that was you at plank lane swing bridge on xmas eve I was the one on the center line after letting cart man over to re set the bridge. Have a good trip..
  16. As said. Grinder with 1mm disc...try a flapper disc if it's only a couple of mm
  17. I would stick with what you have. 5 years is excellent.
  18. I took 12 - 600x600x50mm flags out. the boat lifted enough to leave around 40mm clear under the gas locker vents at the front. The back lifted around the same. I didn't weigh the slabs but would estimate about 540kg of ballast out. Around the same as my batteries and sofa. No difference that we have noticed in roll/stability. Also nice and dry under there. If I need to add any in future, I may go down the cans of cider route
  19. I have the same problem with water on top of the cassette. I got fed up today so removed the toilet to sort it out. It turned out to be a tiny leak from the joint from the hose to the electric valve. The rubber washer was full of limescale and the screw tightener was just a little slack. I changed the rubber washer (same as in normal garden hose fittings) and also used ptfe tape on the thread. After a good cleaning inside, refitted the toilet and made sure it wasn't leaking. To make it easier, the toilet bowl can be removed by undoing 10 screws from where the cassette fits. (5 plastic fittings to let the bowl turn) Easy to relocate and refit. only bad bit was moving all the things she had stored under the bed so I could get in....
  20. When i put them in I also used their positioning to even the boat out. They are almost central to the boat in both axis, maybe a foot or so to the opposite side of the engine (if that makes sense) my boat is 57ft. I will be removing some and will be doing it evenly. I''m slipping the camera in to have a good look around tomorrow before cutting sone holes to get it out.
  21. When I say floor is up, I am down to the ply sheets. I'll either move some of the fixtures or cut my way in.
  22. Yes .floor is up and ready to go.
  23. My batteries are at the middle of the boat. They are around 460kg. The gas locker drains can still let gas out. I was just going to take some weight from under the batteries to even up what I put in.
