Proper Job
Proper Job last won the day on May 16 2014
Proper Job had the most liked content!
4 Followers
About Proper Job
  • Birthday 07/09/1959
    Oxford 'ish
  • Occupation
    Non
  • Boat Name
    Cloudberry
  • Boat Location
    Oxford
13,392 profile views
Proper Job's Achievements
Veteran
Veteran (11/12)
147
  1. Does anyone know how the works are going on the Watford flight? Are they going to be open for Saturday? I need to move a boat from Welford to Aynho for close of play Monday Cheers 🙂
  2. http://www.thruppccc.org.uk/content/moorings
  3. Next time my CO alarm goes off, rather than open all of the doors and windows I'll do a controlled evacuation through a scrubber and recover the carbon All need now is for Biz to knock something up
  4. Just found this on a salty rag forum: http://www.ybw.com/forums/showthread.php?258234-Mastervolt-Battery-Charger-does-not-start Maybe a couple of capacitors gone(?) Time to have the cover off in a nothing ventured/nothing gained look
  5. I'm pretty sure that any carbon based material when 'baked' at the correct temperature will give off a carbon based gas that can then be stored and burnt at a later time.. Not sure about diamonds
  6. Bloody thing still doesn't switch on properly when on main shore power!
  7. The SmartGauge owners manual is a good read. If for nothing else than Gibbo's writing style and forthright comments http://www.smartgauge.co.uk/pdfs/manuals/sgaugeman_r203.pdf
  8. I think natural gas would suffocate rather than being toxic That's presuming that no one introduces a spark or naked flame before it can take effect
  9. Mine went a bit funny last year. Similar symptoms to the OP's. A reset sorted it out. There is some anecdotal evidence that long term use with solar charging can upset SmartGauges(?). I'm certainly a long term user of solar, but couldn't confirm if that was the problem. I also had a problem with my start battery alternator and for a period of time would temporarily connect the engine start battery bank to the domestic bank. The SmartGauge didn't like that either and had to be 'reset' They're great tools for battery monitoring, but not infallible.
  11. Have you done a restart following power failure or a restore to factory defaults? Restore to factory defaults is: 1. Disconnect the power feed to SmartGauge (maybe just pull the fuses out?). 2. Press both the Volts and Status buttons and keep them pressed. 3. Reapply power, still keeping the buttons pressed. 4. SmartGauge will display the software revision as usual. Keep the buttons pressed. 5. SmartGauge will display the battery model revision as usual. Keep the buttons pressed. 6. The display will go blank. 7. Remove your fingers from the buttons. 8. SmartGauge will flash “Fr” (Factory reset). 9. SmartGauge will completely reset its internals to the factory defaults. If you've set any high/low alarms etc, they will be lost
  12. The charge voltage seems about right then. It might be worth 're-setting' your SmartGauge.
  13. All the more reason to fit CO detectors. Did they ever bottle town gas for 'portable' use?
