hovrin
PatronDonate to Canal World
    Cleethorpes
  • Occupation
    Maintenance Engineer - Retired
  • Boat Name
    N/A
  • Boat Location
    N/A
2,640 profile views
hovrin's Achievements
Contributor
Contributor (4/12)
  • Patron Rare
Recent Badges
19
  1. I just knew I had forgotten something - duh. 🫣 I Like the sideways mounting idea though.
  2. Maybe you could extend the pipe work at each end upwards and then fit the radiator upside down - just a thought.😇
  4. As I understand it Neeva is not a browser. It is a search engine which you can use from your present browser. I use Firefox and when I went to the Neeva website it offered me a Firefox add on.
  6. Just a thought for Amanda. Have you thought of selling limited edition prints of your paintings. These can be authenticated with a certificate and it means that you can 'sell' a painting many times. I have quite a few prints as well as some original paintings and, when done properly, they can be just as impressive as the original artwork.
  7. Some of those paintings are almost photographic! Truly impressive. You should both be very proud, you of your daughter and her of her work.
  9. Although many people don't realise or can't be bothered, this should be the first thing you do when setting up any wi-fi, network or bluetooth device!
  12. I'm not an electrician (though I have rewired two houses) but it sounds to me like an earth fault. As TheBiscuits says, unplug everything first. Then if the problem remains, with the isolator switch off, check for continuity from live and neutral to earth. If that exists then you will have to work through your sockets one by one, removing the covers and checking the connections.
  13. Yes, thanks for the update. Good to know that your decision is made and that you are comfortable with it. I hope your test results give you good news and good luck for the future.
  14. Over complicated answer to a very simple problem - just use an ordinary vertical spirit level.
  15. If your phone still works and you have a laptop/PC computer then I would recomend a program/app called MyPhoneExplorer. It lets you look at all the files on your phone and transfer them to the laptop/PC (as well as doing other things). It connects using cable, wifi or bluetooth and once installed is very easy to use.
