Rob-M
Rob-M last won the day on August 14 2021
Rob-M had the most liked content!
About Rob-M
  • Birthday November 16
    Bristol
  • Boat Name
    Resolution
15,071 profile views
Rob-M's Achievements
Veteran II
Veteran II (12/12)
  • Event Master Rare
Recent Badges
2k
Community Answers
  1. We used Symphony Ferrari red but only on the handrails. As Dave said it does fade quicker than the greens we have.
  2. Have you seen the closure notice for lock 15 that has just come out.
  3. Our current plan for end of August is to head along the Staffs and Worcs and maybe in to Brum or down the Severn but under review on a regular basis.
  4. Had this issue on Scorpio as had to move all the ballast barrels towards the bows to ensure the deck board and mast cleared Gosty tunnel but then the uxter plate was a couple of inches out the water and towing a butty made for very slow going.
  5. Or maybe just massively under funded.
  6. Title case is the term used for having each word in a title capitalised.
  7. Gailey to Birmingham can be done in two days via Wolverhampton 21. Depending on the time you left you would probably be arriving and leaving Birmingham on the same day so not much time to explore.
  8. We've got swarms of ladybirds today.
  9. The pride of Gloucestershire, https://www.punchline-gloucester.com/articles/aanews/video-the-pride-of-gloucestershire-is-let-loose. The lions will be auctioned to raise money Ney for the Cheltenham cancer care unit.
  10. I presume that is Gloucester docks.
  11. I think we were moored at either Tewkesbury marina or Bredon in 76 so holidays would have probably been up and down the Avon.
  12. Not sure what you are after the CRT notice tells you the flight, locks 1-6, are open 8am - 4pm with last entry at 3pm. Not sure CRT should be expected to make recommendations on good mooring spots above or below the locks.
  13. Putting in Coventry canal I get... Original 24 June 2025, 2:50pm Following the driest spring in a century, water levels in some of our reservoirs have dropped. To help conserve the remaining water, from Tuesday 8 July we will be reducing the opening times for Atherstone Lock 1 - 6 from 8am, to close at 4pm with last boat in at 3pm. This collective action is being introduced on Claydon, Foxton, Marston Doles, Hillmorton, and Watford Lock Flights. The aim of this evening restriction is to reduce water demand and allow water levels to recover, which will mean that there will be more water available for daytime journeys. We hope this coordinated action will allow for your continued enjoyment of our waterways throughout the summer and that providing this advance warning will allow you to make suitable plans. Thank you for your understanding. An update will be provided by Friday 1 August or sooner if the situation changes.
  14. If you select specific waterways on the stoppage page it will show notices.
  15. We've been in Great Haywood for approaching 10 years, we like it as a base as there are plenty of options for weekends, short trips and longer trips.
