claudia
Everything posted by claudia
  1. If Chris Pink sells me his 19x12 lh I would have a virtually brand new 17x12 lh to offer into the fray.
  2. If I am reading this right you should never step down a flue size, if it starts four inch at the fire it should remain four inch or bigger never smaller.
  3. Don't get me wrong Rodentlover I do like all those things about a Lister thats why I have 2.
  4. Thats what I wanted to know Bizzard, now I just need to lose 5 stone to get in there to take it off cheers.
  5. Silly old duffer I am it would help if I gave a full discription its a Lister ST3 I am refering to.
  6. Hi could somebody please tell me, do I need to drain the engine oil out if I take the governer/ camshaft end case off cheers, Ian.
  7. If we all had your attitued then the canal network would just fall into disrepair, in an ideal world the revenue would pay for people to do the work and all would be well but its not.
  8. I've been a plumber for 19 years and not found the need to use ptfe, I have been known to use boss white if I thought the pipe had imperfections but I stick by if you apply the right torque they are as good dry.
  9. Nuts and olives work very well as long as they are not overtightened and its a good thing to go back around them a week later with the spanners(ones that are near enough)and just check as heating up and cooling down in any degree can stretch them initially.
  10. claudia
    Governer
    I will strip the front of the engine down if I have to to get to the governor I just didn't think it had anything to do with the tickover, my thoughts were it controlled the limit the engine could run now i'm not sure.
  11. Yes that does sound a massive job Blackrose, never liked the thought of painting upside down but thought that is what had to happen.
  12. Having never blacked a boat I have found this very interesting so nobody paints the bottom of a flat bottomed boat, is that right?
  13. It will run fine been doing it over a year, you have removed any problems you would have by using a day tank just keep an eye on your water trap.
  14. claudia
    Governer
    One day I will have a straight forward problem!!
  15. claudia
    Governer
    Would an air leak show as a diesel drip?
  16. claudia
    Governer
    I can't set a tickover one time it will sit at a reasonable speed then after awhile it will speed up to three times the speed then on other ocassions it will sit at a resonable tickover for twenty minuets then just drop off and stop there is no set pattern. It can do both Mike. Sorry not to acknowledge your post Les it's good to hear from you again and I hope that shiny green SR is purring away in your boat.
  17. claudia
    Governer
    Could somebody help me with my question which is does the govener have any effect on the tickover and say if a spring broke would the lack of tickover be a sign of this cheers, Ian.
  18. Am I right in my understanding from this topic that the governers do have a bearing on the tickover and that a broken governer spring would affect said tickover.
  19. Only go for a boat with a lister engine in if you are happy to have a noisey, smokey, oil leaky, vibrating large lump of british metal next to or under your feet.
  20. If the primary or hot pipe is to close to the cold then heat transfer will take place and warm the cold water giving a short burst of warm water each time you use it. This is also a very good way of contracting legionares.
  21. claudia
    Bell housing
    Hi does anyone have or could point me in the right direction to locate a what I believe to be an industrial gearbox to bell housing shroud, this is a very shallow one and features on a video page 3 SR2 smoking cheers, Ian.
  22. Speedfit have just brought out there new layflat pipe so its even more flexible and easier to use.
  23. Sounds like you have a heat exchanger problem and its kicking out on the over heat stat.
  24. Could somebody please explain whats involved in turning a fixed speed Lister into a variable speed based on a ST or SR cheers, Ian.
