Days Won
Everything posted by IanM
Building a Category C narrowboat!
IanM replied to dreamboater's topic in Boat Building & Maintenance
I have seen a narrow boat up here on the Stour estuary in Essex before. No idea where it came from or where it went afterwards. -
It is the Thames & Severn but further east from Chalford. It’s Daneway Bridge with the wharf cottage on the right. Beneath the bridge is the infilled Daneway lock which currently serves as the car park for the Daneway Inn. It’s the last lock up to the summit with Sapperton Tunnel not far away.
Seems that no one really knows the origin of 4' 8 1/2" https://en.wikipedia.org/wiki/Standard-gauge_railway
I've not seen any image of any loco that I can recall and I'm trying to think of anywhere else it could have been used. The other pictures taken at the same location as yours just show one or two small trucks the same as in your photo. The location in your picture is marked quarry in this map. The GWR Cirencester Branch is in the top left. And the location today. https://www.google.com/maps/@51.692671,-1.9762233,355m/data=!3m1!1e3?entry=ttu
Thames & Severn Canal at Bluehouse.
Enlarged picture of Raven from the other end to my previous picture showing the plates being discussed. Actually it looks to be more of a single plate as it wraps around the stern but whatever
It’s not. As I mentioned earlier, Achilles was a butty owned by Birmingham & Midland in Gas Street. It went from them to Roger at Braunston who then cut it in two. Raven (the name given to it by Willow Wren) was another butty and had a full length cabin fitted but I forget its original name and was moored outside Roger’s yard at one point but I’m pretty sure it never got cut in two by him as I saw it still intact somewhere else afterwards. Edited to add: Raven was originally the GUCCC butty Hydrus.
Achilles used to belong to Birmingham and Midland and was moored in Gas Street basin.
Is that the one in question or the one in Foxton village itself? Edited to add: According to the stoppage notice it is bridge 4 so not the footbridge at the junction as per the OP, rather the larger vehicle bridge in the village.
Knowle locks are the ones with the larger culverts so I imagine that has something to do with it.
There and back again: Saul Junction to Ebley by canoe
IanM replied to Francis Herne's topic in Cruise Diaries & Reports
We added that beam to support the centre post for the stop planks. The centre post was added to add a bit of support to the centre of the planks as they are 16 feet long and we were using them over an extended period of time. The lock had a fall of 6 feet or so before the ship canal was built when the level change became a few inches meaning that quite often the top and bottom gates were left wide open. At some point concrete copings were added to raise the level of the walls a bit so that the lock had to be used and this is can be seen today. The bottom of the lock is still at the original pre-ship canal level so there is essentially a full lock of water there. In the 1990s we sheet piled a dam at the lower end to excavate the chamber (it had been infilled) all the way down to the original bottom which is constructed out of stone blocks. A concrete plinth was then constructed up to 6 foot below water level which we could then sit stop planks on that along with a socket for the centre post. At other locks we had used cables to anchor the post but we had a beam lying around which did the job instead. The gas pipe as you refer to it is actually part of the countrywide Exolum aviation fuel pipeline. https://en.wikipedia.org/wiki/Exolum_Pipeline_System -
I can't think of any emergency where the ones at the lower end of the lock would be of any use and they really would only get used to de-water the lock. The ones at the head of the lock would be more useful and easier to put in too.
They would have been put in the slots by a maintenance team with the necessary access to boats, ropes, etc and not just one lonely lock keeper. Plus they do float a bit too.
A good list and pictures of the hulks at Purton https://www.friendsofpurton.org.uk/purton/
*checks date*
A friend of mine from primary school owned the ex-submarine one a few years back.
Tony Jones told me that he once rigged up a sail on Betelgeuse and untied from the motor when on the River Severn just for fun.
Every time I see a picture of it now I remember your comments when I posted a picture of the cabin being extended. Little did anyone know what an absolute mess they'd eventually make of it.
Restored yes, built no. Although that will soon change. Besides, the OP specifically asked about narrow locks although in fairness there probably isn't that much difference in reality.
I'm really not sure why you feel the need to stop. I think everyone has been enjoying your pictures and stories.
Some more info on the grain barges https://www.gloucesterdocks.me.uk/vessels/grainbarges.htm I remember seeing either Tirley or Chaceley pass through Gloucester sometime between 1994 and 1996 when I was at college.
It's not the River Stroud by the way, it's the River Frome. It was once called the Stroudwater but not for many years (probably since the Stroudwater Navigation was built).
Not sure if Napton Narrowboats rent their wet dock out or not but it could be worth asking them.
Apologies, I was certain that the motor didn't have a cabin when we last passed them. However that was 18 months ago and I've been to the pub since then 😄
