Flocal
Everything posted by Flocal
  1. Ah ok. I will try giving the screws a slight tighten then. Cheers
  2. Ok will do.. Although first inspection it seems as though the seal is almost rotting, it's not a smooth edge. Almost pitted a bit. Tightening might finish it off...
  3. Cheers Roger, yes that's the one. I've had a diesel leak for a while and had trouble finding it. Whilst removing all the floor boards to get too the starter I had a mooch about. Seems the seal between the Base of the pump and the domed top is perishing. It looks to be weeping.
  4. The bracket where it was fixed was not twisting...after the bracket is a thin what looks like a seal about 3-4m thick, then the main starter casing. It was twisting from that seal, just the main body, not at the bracket. Taking starter to reading today to be reconditioned
  5. Everything seems to be turning fine, no oil loss... Why was the starter motor making a like a grinding, clunking noise? When I tried to start it a second time I was down in the engine bay and when I turned the key, it was slightly twisting a bit too...
  6. Just out of interes... On the opposite side of engine to the starter, injection pump etc, below the air fifilter. Is a small domed case, with a fuel line going in and out, with a rod ontop attached to a spring, what is this?
  7. Easily as in, had too use both hands and it spam smoothly.
  8. Phew....just remembered. My boards are made up of five panels and one is right above the engine. Been in and yes, engine turns freely. Turned it quite easily full cycle.
  9. Ok thanks, will have a go tomorrow. Thanks guys, really appreciate it Clock wise or doesn't matter
  10. Ok, so where do I put a spanner, I haven't a clue. I'm assuming it is one of the wheels with the belt in at the end. Oil is fine, checked the dip stick as a matter of routine whilst I was investigating the starter. I want to check Mike, just not sure how...
  11. Be surprised if it was seized, oil is absolutely brand new, engine ran sweet only three days ago... Could it be something else
  12. The existing one looks more like the other one on ebay... Hmmmm make sure engine is turning, now it doesn't sound like a job for me :/! Why would the engine not be turning And what if it isn't, not quite a simple swap them?
  13. Will get and order the listed eBay item tomorrow then.
  14. Ok that seals it then, cheers RLWP, I will get a new one... Is it just a case of remove old and put new one on, no timing etc
  15. Would that make a difference to the recon? RLWP is it worth replacing the wire that got frazzled and giving it a whack? Or is the clunk and the wire shorting a ding the starter has passed being hit hard? I'd like to understand what has happened
  16. Tried starting engine today....starter made a horrible grind noise, clunking, no start. Then a real bad burning smell. Investigated and the 2 inch cable from Solenoid to starter is frazzled!!! Been told the starter is buggered. Can someone point me in the direction of a new one, can I goto a auto factors or specialist? Cheers
  17. Flocal
    BMC 1.8 Fuel Pump
    Ok..I think I've found somebody who will remove it for me, and a specialist in Swindon. And then same guy to refit and time. My problem is Christmas, new licence in January equals no cash. No pump means no power....so looks like I got to wing it until March when hopefully the sun will provide the solar and I won't be as reliant on the engine. Bugger
  18. Flocal
    BMC 1.8 Fuel Pump
    Looks like it's leaking all the time now and not just when the stop cable is pulled!
  19. Cart, Parry and the IWA can go take a long jump now...time to concentrate on the important matters and stop picking on the minority. Brilliant news.
  20. Bimble solar, nowhere else. No need townshend mega miney In English.... No need to go anywhere else
  21. Apparently the car park at All Cannings is being shut and the parking down the avenue at Wilcot is being double yellow lined
  22. If the plug is correct size, would this be suitable? That's the lead I'm after 12v cigarette one en
