Stormbringer
Stormbringer last won the day on March 11 2012
Stormbringer had the most liked content!
1 Follower
About Stormbringer
  • Birthday December 25
    Another DImension
  • Boat Name
    'AJ'
Stormbringer's Achievements
Community Regular
Community Regular (6/12)
18
  1. Have had this issue when one of the belts on my Lister 4 pot engine was slipping due to high alternator load / slack belt combination. Might be work another check of the belt tension / pully condition.
  2. We learned to share also..... Just wish they wouldn't crap on the curtains tho
  3. Just saw the other thread too....hmmmm.
  4. Why do humans always want to kill natural things that don't behave as they want them to ? And just exactly what damage is a swan, with its plastic beak, no teeth, and hollow boned wings going to do to a dog full of teeth and claws, with a natural, inbred killer instinct (ie a hunter) ? Also, monetary value has no sway in the natural world, ....all animals being equal and all that...
  5. Brass thingy is the gas valve .....and yes, that is where the controlling bit happens ....
  6. That will work...I have a modified hook up lead with the live available for a clamp meter...very handy
  7. Your fridge would be iced up and food on the top shelf would probably start to freeze. If unsure I would monitor the fridge with a clamp meter ..they pull about half an amp @ 240 v
  8. Lol...not sure where that came from Must be the coffee
  9. The one thing that the TP wins hands down on is it's integration with the boat. It take very little space up.....and is dead easy to use....
  10. Quality reply Alan
  11. I love mine I can run washing machine whilst cruising. Run engine for less time when charging batteries, same for getting hot water..use big power tools when out on the cut without hammering the batteries... It came fitted to the boat...but I'm not sure I would cough up for a new one , I don't think they are cheap! This is probably what I would do, for the exact reasons CT has stated here
  12. You could try and get the examiner who wired it to 'educate' the one who failed it!.....and then report him anyway.... As others have mentioned above he doesn't sound competent ..
  13. Yes...if you can get the fridge out ! Just a resistive heating element , one for 12v and one for 240v .. they are tucked in the side of the insulation around the boiler section of the fridge, and they connect on top of the fridge electrically. The test to see if they are the problem is again an ohms reading...around 420 iirc for a good mains one...it's probably gone open circuit if it hasn't taken the fuse out. Replacements available from online caravan spared suppliers ... Cheers
  14. Something wrapped around the prop maybe ?
  15. They do actually exist! Sadly not common enough though...it just seems too low down the' must have' list for new buyers...and then just gets left as is I guess as the boat gets sold on ......
