Rob99fla
Gender
Rob99fla's Achievements
Contributor (4/12)
10
It wasn’t very clear what it meant. He made assumptions the heater and exhaust is in the accommodation area. It’s not. Also, it does not leak exhaust gasses
Mines been fitted in 2019. Not a single problem in all this time. Brilliantly piece of kit. If I can help, let me know
It’s my boat. The silencer is welded at the edges. There is no drain hole. The clamps don’t leak exhaust gasses. The silencer is in the engine bay. A top technician from Autoterm visited the installation as the heaters were in their infancy in 2019. He was complimentary about the standard. The boat safety inspector inspected the installation at the last safety check and was very happy. I’ve never seen a narrowboat with the silencer mounted externally either. We run the heater everyday and I there is no exhaust leaking from anywhere except outside the skin fitting. The boats diesel engine silencer is in the same engine bay space so you suggest this silencer is moved to the outside of the boat too? So, it’s probably best to mind your own business and concentrate on your own boat (if you have one!)
A good find explaining the situation clearly. It might stop some people harking on about diesel generators producing electricity. It’s about diesel heating. A separate tank for the heater shouldn’t be too difficult for a competent DIY’er but will red diesel be available any more to boaters. We will have to wait and see. Someone told me that red diesel is basically heating oil these days. I know my new Planar (Now Autoterm) 5S runs beautifully on the red diesel I buy
That’s just what I thought ?
Agree with all of that. As I mentioned in another reply, boats make up a tiny proportion of the total 15% red diesel use. It might just be a simple fixed 60/40 as some suppliers do anyway. Anyway, it’s not until April 2022. It’s aimed at the construction industry which will lose between £280m and £490m a year (Civil Engineering contractors association figures)
Correct. It says April 2022 to allow industry to adapt. As far as I have read, red diesel accounts for 15% of total diesel use. I imagine boats make up a tiny proportion of this.
I can see the only real solution is a separate tank for your diesel heater/stove. If it meant being able to use red diesel for heating (which we use at 100% as we are on a static mooring and not moving at present), I would fit another plastic tank. Using white diesel to heat your boat all winter would cost a fair bit more (about 40%?) Interestingly enough, camper vans fitted with diesel heaters use white road diesel and I haven’t heard anyone complain (yet)
Yes, its working well. I have fitted a heat shield to cover the top of the exhaust now as its close to the piece of flooring. Might put a bit more lagging in time for BSS check next July
Hi. I’ve just fitted a Planar Binar 5S-12TM to replace an old failing Mikuni MX40. The old pipe work was all 15mm so I’ve replaced in 22mm from the heater to where it splits to the fin rad and calorifier circuit. I’ve also fitted the expansion tank as 2 pipe tank on the return. I got this idea from an Eberspacher guy, Peter Collard. This is the link giving good tips on heating design for boats (https://www.canalboat.co.uk/canal-boats/maintenance/how-to-make-sure-your-narrowboat-is-heating-up-properly-1-4822255) Anyway, back to the Planar Binar 5S. It started up fine once the fuel comes up the line from the pump. The heater is modern and quiet compared to the old Mikuni MX40. The fuel pump is a bit loud, especially at 7am when ou r boat is silent as we sleep. It sort of thumps at first until it gets going. I might sound proof if a bit. You can buy a new silent pump. If you buy the kit, I would specify this addition. The heater is very well built and looks very solid. Also, it requires no servicing except being run for 30 minutes every week or so. Finally, the spares are far cheaper than the Mikuni MX40 and I suspect Webasto or Eberspacher too. Am I happy. I should say so. It cost £650 including every bit you might need to install plus I bought the Smartphone modem for £99 so I can control from my phone using their app. See my pics of heater installed. PS I’ve now changed the water pump to the return pipe on advice from Planar Heaters Uk and now fitted copper fuel pipe in case any eagle eyed points out I’ve used nylon pipe
I need a wiring diagram for a Lister Petter LPWS3. I am helping a friend who has just fitted a Lister Petter LPWS3 engine in his boat after the old Vetus engine failed. The new engine has done less than 200 hours from new as it came from a lifeboat. The company who supplied the engine supplied a basic control panel but no diagram. Anyone have the wiring diagram? I have managed to get the manual but the wiring diagrams are on later pages not included on any downloaded version I can find. Any help with a diagram would be greats the engine is nearly ready to power up.
Thought I’d give an update now it’s been over 6 months since I fitted the 4x new US2200 batteries. Just to say, the batteries are performing very well. As time has passed, they have actually got better. We’ve replaced the 240v fridge with a 12v Inlander and added another 100w solar (total now 400w) and beefed up the solar controller to battery cables. All I can say is that the previous woes of the 4x Halfords 115ahr are over. Over the summer, I’ve not needed to run the engine unless I need hot water when moored up for a few days. Even with the Mikuni running (it’s getting cooler now), inverter on and everything charging (phones,iPad etc), I’ve never seen the battery voltage drop below 12.25 volts under load. Even with a whole evenings TV (240v), the batteries never read below 12.4 in the morning. Any, suffice to say, they done the job for our boat. Hope this helps anyone thinking about fitting US2200 batteries. Yes, I know T105’s are very popular too but I chose US2200 as like to be a bit differently.
Don’t think they had much choice. Our anodes were fizzing away so they wanted us out. It was voluntary to go though
We had a great time in Salthouse Dock, being there for 4 weeks but were ready to leave in the end. We had an experienced commercial operator in a launch type boat to lead us across from Brunswick lock to Eastham lock. Boats were all safety certified, for the Manchester ship canal really but useful. We had to block off low skin fittings, that’s all. Life jackets of course. The crossing was fine but we had to wait outside Eastham lock for 1.5 hours with the wind picking up. A bit scary but we’re all fine. Five more went across safely yesterday too. Really glad we’ve done it as not many can say that on a narrowboat! Glad to be travelling again. Bye the way, the Manchester ship canal was easy. Just like a river really. Followed the oil tanker guided by two tugs, back and front, down the canal. It was 119 metres long!
