sjc
    Not Telling
    Trent & Mersey
  • Boat Name
    Bridie
sjc's Achievements
Engager
Engager (3/12)
2
  1. OK thanks, the whole system has been bled and there are no cold patches on any radiators. But I will try to track this down as it is cheaper than a new calorifier !
  2. OK, thanks for the replies. I realize the water is going somewhere but I haven't found out yet. No obvious liquid in the bilge, although now it is colder there is some from condensation etc. The header tank is open to the atmosphere, and does have an overflow pipe. I monitored the header tank level when I turned on the heating, with heat it went up several centimetres to reach the overflow level, this may be where it gets lost? However, after several uses it would have to rise 15cm to do this, which I cannot understand. Most of the original pipework exists, it was just flushed out when the new system was fitted, the calorifier is 10 years old. I hope I haven't forgotten anything?
  3. Initially we had an old e( working) eberspacher, earlier this year we had it replaced with a new webasto, along with new radiators. It works and heats nicely but loses liquid from the header tank each time. I have measured this and from cold, when the heating warms up the header tank level increases alot more than I would expect. When the heating cools down the level reduces to below it's original level, this pattern repeats until the header tank is empty and eventually the webasto develops a non starting airlock situation. I cannot see a leak anywhere, either it could be behind a wall I cannot get to, or maybe a hole in the calorifier coil? But I don't want change this unless I am sure, has anyone got any suggestions?
  4. Why didn't it halve the current ? Probably because the covered panel was draining some of it, assuming your panels do not have blocking diodes ? The working panel was probably producing half your measured current, some of which went to your controller, the remainder was back-fed through your covered panel. To measure one panel disconnect the other first. As for % of max, we have had upto 90% on the right day, panels clean, properly tilted, batteries on bulk etc
  5. Did anything on the smart charger you installed touch the hull ? ( earth connection, case, mounting screws etc ). The fact the previous owner never left it connected to the shoreline may be answer, maybe EOG moorers should be wary of this and use an IT. Whether it was the soar array or just a floating earth, we may never know unless your insurers look into it further. I hope that isn't the end of your canal boating, the other issue is none of us know how our insurers will respond until it is too late - typical...
  6. Sorry to hear this, a very sad story, it is your worst nightmare as a boat owner. Is it possible the corrosion was already underway when you bought the boat but you were not warned about it ? Failing that something must have changed since you took ownership ? Any new equipment on the boat, any new electrical work done, and changes in neighbouring boats / equipment, did the previous owners keep it constantly connected to the shoreline, have you kept the same mooring, and shoreline supply. Although the GI was working, did it have an LED indicating when it was conducting, and if so did you ever check it randomly to see if it was on. If it spent more time on shoreline than cruising, it is a fair assumption to assume this is where the corrosion took place. The only other possibility is perhaps a faulty supply, with a DC voltage on your earth perhaps ( possibly as indicated on the solar farm document referenced in an earlier post ). ( hence the GI LED question ). I believe marina's must comply with strict safety standards for electrical supply, maybe EOG moorings are unregulated ? Having read this and the other recent thread on corrosion our boat is out of the ware, ha all electrics removed, and is completely encased in fibre glass...
  7. Just did a quick test on my panels : 3 x 100W in series. Blanking out a single cell, then multiple cells on the same panel had a very different effect to that in the video. As I would expect you only lose half a panel for a single cell, or a complete panel for multiple cells. But we don't have the benefit of a clear blue sky so the clamp meter was forever changing. It looked like the MPPT took a few seconds to re-adjust then things continued as normal. So I have no idea what went wrong on the video, they had the perfect opportunity to carry out a scientific test but left unanswered questions instead !
  8. Your description is correct which is why they have bypass diodes, to prevent this happening. Maybe their panels did not have bypass diodes ?
  9. If I have remembered correctly, the series connection dropped from about 15A to about 1A when just s single cell was in shade. I am struggling to understand how this can be true, anyone care to explain ?
  10. This is where the CE markings come into their own. The standard would state the current and duration before a relay could claim to be rated at that value. BUT, how the general public knows which CE numbers to look for is a mystery, apart from Google of course ! Not wishing to get political, but the British Standard kite mark may be making a come back and replacing the CE mark !
  11. I would suggest he following :- 1) Protect it from direct sunlight as this may affect the outer casing. 2) I agree with Tony about the wicking, it is usual to seal the ends with pvc tape or similar to prevent moisture ingress.
  12. I am assuming the Adverc replaces the alternator regulator ? In which case it certainly looks like an Adverc fault. Sadly I am not familiar with the cable colours on your chart, could you add signal names so we can see what each one is doing ( eg : main output, regulator feed, ignition lamp etc etc ). The values you say are varying, are they at the 0.5Hz frequency as well ?
  13. We have the same inverter, and the same problem. It runs for months without the fan coming on, then it will run constantly for days on end. I also wondered if it was more frequent at night, but I don't think it is. At one time I turned the inverter off for a few minutes then back on again and it seemed to "reset" the problem. It had absolutely NOTHING to do with ambient temperature or current drain. I exchanged many emails with the Victron technical contact but they were of no help, eventually telling me to return it for them to examine. I never did as this isn't convenient, at the moment things are quiet ! I wondered if it was a software fault switching the fan on accidentally, but the previous post about connectors is a thought.
  14. Fair enough Dave, each to their own. The shunt method is more common and what people would think of first and foremost. But any solution will involve a compromise, whether people realize or not. I haven't re-checked the specs recently but seem to remember linearity <1%, and the electrical isolation appeals to me. Also, with a shunt ( say 200A == 50mV ) you will need to use an op-amp that will run off a single supply ( 0 -12v ) AND operate right up to its' voltage rail ( not all, especially the cheaper ones do this ). Otherwise a dual rail device ( +/- 12v ) could be used. As for accuracy, to detect 50mV on a noisy electrical system is quite an achievement, as for your 1A error, that involves a 0.25mV drop across your shunt, you do not have a hope in hell's chance. People think because the display shows 3 or 4 decimal places it is accurate, often those digits are a work of fiction ! ( unless you spend a fortune on expensive circuitry ). Even 10A requires detection of 2.5mV, if you put a scope on the signal and checked out the voltage spikes you would appreciate the challenge. You will always have a value, and a figure on display, but it is not much more than a guess ! There are clever filtering techniques but you would need a Paul Daniels filter for that ! Good luck and please post back the outcome !
  15. This subject has come up before so if you search the forum you might find it. I would dis-regard the shunt method altogether and get a hall effect current sensor ( see link below for examples from Farnell ). I doubt they are more expensive than the shunt ( with extra electronics required ), are more accurate, more linear, provide electrical isolation, and give a simple analogue voltage output proportional to the current. ( probably 0 - 5v or similar which could be reduced with a simple divider ). http://uk.farnell.com/webapp/wcs/stores/servlet/Search?catalogId=15001&langId=44&storeId=10151&categoryId=700000005923&st=current%20tansducer&beginIndex=1&showResults=true&aa=true&pf=110151160
