Canal World
Join us absolutely Free in just two minutes to gain access to all our features. Once registered, you will be able to submit new content and get answers to your all your canal & boating questions all for absolutely Free!
arpeeuk
  • Content count
    156
Community Reputation
3 Neutral
1 Follower
About arpeeuk
  • Birthday 03/09/59
    Kintbury
Previous Fields
  • Boat Name
    Jupiter
  • Boat Location
    Kintbury
Contact Methods
  • ICQ
    0
  • Website URL
    http://
  1. Do keep you eyes on the winter stoppage programmes while doing your planning. My reading of the CRT & Thames stoppage program says that you need to be back to Newbury by 3rd November or you could be stuck on the Oxford until nearly Christmas. Also bear in mind when doing your planning that we might have a lot of rain and that the Thames might go on to red boards so you cannot use it. The fact that there are red boards will not delay the Thames stoppages. I know this from bitter experience a few years ago while trying to get to the K&A during October, I got stuck at Abingdon on red boards, it was a nail biting time waiting for the river to drop while the start of the winter stoppages drew ever closer! Fortunately I made it with just a few days to spare. Rik
  2. You'll find the latest advice from CRT here http://canalrivertrust.org.uk/notice/778/river-kennet- it ends "Although the navigation is open, our strong recommendation is not to move your boat unless absolutely necessary and you are confident of your ability and the capability of your craft. If in any doubt and you are safely moored, stay where you are. We anticipate that in another week’s time, the river condition would have eased further." With advice like this I wonder what our friends, the insurance companies, will say if you travel and have problems Rik
  3. Mine also rattles at tickover so if it is a damper plate it hasn't cured it. Rik
  4. Also, on mine with the standard PRM 160D gearbox, the drive plate is a R&D 55A21. There is a plate on the case above the gearbox which you can remove to see the drive plate. If you get someone to rotate the engine while you will watch you can see the numbers stamped on the plate. This is what my engineer did to find out which plate I needed. Rik
  5. This is the information that I got from Neil at Beta when he asked me for the engine number. The engine serial No. is usually on the left hand side, looking forward, and is on the web along the lower part of the block. It will probably be of the format - seven No’s beginning with 4 CRK3A Three No’s beginning with 0 Typically – 4300014CRK3A041 Hope this helps Rik
  6. Yes I personally know someone that has successfully claimed housing benefit. He's had two claims in different parts of the country. In the first he managed to claim licence fee, 3rd party insurance and boat safety, at the time he did NOT have a permanent mooring. In the second he gets licence, mooring, 3rd party insurance and boat safety. As he has a kid aboard he also got social services to spend £5k fixing various bit on the boat, new cooker, new shower, replacement water tank were the key things. Key thing is , never give up, if your claim is rejected appeal, if your appeal is rejected submit a new claim, make sure they give up before you do! Rik
  7. I was told by one of the CRT guys doing the work that the stoppage before Christmas was to repair the channels in the wall above the lock that take the stop planks. Looking at Gillie's photo ,I guess the stop planks won't not come up high enough to enable them to stop the flow and so the official stoppage is now delayed. Rik
  8. Got my kipor from the Green Reaper at Thame. Don't know if you can collect but maybe worth a call. Rik
  9. I have a feeling that some detectors also detect hydrogen which you'd get from battery charging. Is the 140 number constant? Are you constantly charging via a landline? Have you tried swapping the position of the two detectors to check that one isn't faulty? Please be careful and keep safe Rik
  10. Is this similar in principle to the old barge that the boatyard uses as a dry dock by Denham Deep? Sounds a good idea to me and may help provide more dry docks around the system Rik
  11. Think you mean the Fisherman's Cottage right by Blakes Lock? http://www.fishermanscottagereading.co.uk/
  12. Won't be Norman I'm afraid as he passed away earlier this year. Lancing is, I believe, up for sale. Rik
  13. Had a new one fitted for me yesterday. Assuming you have a new squirrel with the heat shield on the back you need to Remove the heat shield - this is not required with a back boiler Locate the dimples on back of stove that mark position for the boiler pipes Remove back firebrick and baffle plate -these are not required with a back boiler Drill holes with a hole saw Fit boiler ( found this was easiest by removing top from stove first) Seal around pipes - my installer used something like this http://www.amazon.co.uk/VITCAS-Black-Fire-Cement-1250/dp/B004646CLM Tighten nuts Hope this helps Rik
  14. Have you looked into buying a 12month standard canal licence and then upgrading it to Gold? I believe that CaRT will refund you and whole months on your standard licence when you upgrade. This way you'll probably have to pay for a month more than you need but this is a lot better than wasting 9 months of a gold license. Rik
  15. How about installing some davits and hanging the boat over the water? It would stop having to use your garden for boat storage. Rik
