Chris G
PatronDonate to Canal World
Everything posted by Chris G
  1. That should work. Might end up with a slight ripple in the flange (upturn) though - out of sight when the hatch is closed.
  2. Hull speed = 1.34 x sq. rt.(Water line length). For a 48' LWL that gives 9.3 kt.
  3. Thanks Tony; I managed to pay without setting up a PayPal a/c.
  4. How do you pay without setting up a PayPal a/c?
  5. I believe that the metric pipe thread IS BSP!
  6. With the bypass valve closed, all the return flow has to go through the header tank easily releasing any air. It's not often you don't know all the answers 🙂!
  7. My 1980 Yamaha 85 had a kill cord and couldn't be started in gear.
  8. "shock tested between -4OOºC ..." - interesting temperature: -273C is absolute zero.
  9. I don't think that carbon dioxide and water are toxic.
  10. Self adhesive magnetic strip: https://www.amazon.co.uk/Magnetic-Adhesive-Tape/b?ie=UTF8&node=1938391031
  11. That's how they stopped the crack in Big Ben.
  12. Yes the fatigue crack started from the stress raiser at the sharp bend. Be very carful with a welded repair: the fatigue strength of welds is much lower than that of plain plate!
  13. I think you'll find that Nylon is a thermoplastic. As a aside; my mother was a co-author of a paper (Proceedings of the Royal Society) on the crystal structure of Nylon.
  14. Brass screws and aluminium frames sounds a seriously bad idea when it all gets damp.
  17. Polyester is not regarded as a good adhesive - perhaps why it's not used as a paint.
  18. Take out the glass and you're left with polyester, not epoxy resin. Not the same thing at all!
