mickp
Everything posted by mickp
  1. I just saw 105 mentioned as battery type ,thought he may have brought a 6v battery ie trojen which would cause the issues .
  2. Is the new battery (105) a 12v or 6v variety
  3. It an isolated canal so ccing back and forth the only option
  4. Over filling and releasing excess water maybe the reason Miss read your post so ignore the overfilling comment
  5. I've stopped at bridge holes on hearing a horn a few times then wait ages for the boat to appear ,I think a few use the horn to give them selves right of way.
  6. When I fitted my new plastic tank I put all fitting thru the top as was the tank it replaced.seems less chance of contents emptying into boat .
  7. Are there any rumours of supply improving,just switch over To my last bottle 3.9 propane which will be ok for about 2 weeks,so no panick yet,but was panicking before setting off on this 4 week trip and had to do a drive around looking for refills
  8. Some cookers come with different jets and instructions how to convert. You change the jets in the burners and I had to remove control knobs to access adjustment for flame hieght on low or simmer setting.all settings given in detail in the instructions
  9. Didnt spot that one,just assumed mobile use but it is specific about not using in boats a caravan. I suppose it's because of boats and caravans can be very close to each other and interfere with nieghbours maybe
  10. I have been googling this subject because at some locations I need to go outside of boat ,ok with warm sunshine ,to get any internet or calls. There are booster for cell phones but ofcom made some illegal ,so they are for sale online but you need to check it's the legal type .if advertised as open to any network it's the naughty type and can cause interference. Legal ones are setup for the network u use. I dont have one so not sure there any good ,and my info is just what i picked up with 1/2 hours googling
  11. Once the stoves lit you will be looking to remove the excess heat that soon builds up ,I'd allow good air flow in bilge area ,if it gets any water down there it will be easier to dry out.if using laminate or carpet flooring u could fit underlay first
  12. When I had a dish I set it up then glued a spirit level bubble (just the glass part) so that you can quickly adjust the up/down part then a compass to find south then slowly turn dish till u hear the tv come alive .didnt have signal finder . When I had a dish I set it up then glued a spirit level bubble (just the glass part) so that you can quickly adjust the up/down part then a compass to find south then slowly turn dish till u hear the tv come alive .didnt have signal finder .
  13. Since freeview upped the power and closed analogue tv ,I dismantled the freesat as simple omni antenna and amp lifier work well enough ,and simple to just raise pole ,and return if moving to new transmitter
  14. Drop down on the weaver ,a nice relaxing week
  15. Theres 2 sats very close to each other and easy to point to the wrong one ,so will show a signal on ur meter but wont decode
  16. Once the engine circuit has pressurised by domestic pressure then it would be only leak slowly when it over comes pressure cap maybe
  17. If your engine heating coil in the califlower is pin holed then water pressure from domestic supply will over flow in engine coolent circuit The picture shows pipe and container connected to engine coolant tank ,why i think the above is happening
  18. Without looking in manual for bvm ,the voltage reading showing in pic is the upper and lower alarm settings,cant remember how you switch out of setup mode but when out of there you use the up down arrows to show volts amps state of charge time left to go etc .i only ever bother watching volts amps .
  19. Looks like the bvm is in setup mode ,thats not showing actual volts or amps or soc readings
  20. Lollypop stick on the ecofan
  21. Was moored in aston marina ,it has a jd3 engine if i remember .
  22. Yes dave ,alan said you did the paint work .it made the front cover of a boat mag in 95 which was given to me not sure if you did the repaint (not sure what year that would have been .
  23. My orion was launched feb 95 at brockmoor.it was then sailed to ashwood for final fitout so must of been one of the last few to be built there.im the 2nd owner but the original owner gave me launch photos and full history .i brought the boat via richard brokerage and he gave a lot of time explaining the orions build design etc .
  24. Well my dearest would have words if i didnt I also have to close the lid .hard life
  25. Hi Im getting a small leak on the toilet (but getting worse )from the doughnut seal,i changed the seal on my 2 cassettes a few weeks ago which stopped the leak but after a couple of weeks it started again .i use silicon spray on the rubber and the flange where the seal joins the loo to casette is clean.i can only think there is wear on the cassette or bowl stopping the meeting faces being tight.any thoughts please .the toilet is 6 years old not sure about cassettes but proberly 3 years old and on there 2nd seal o think
