thenightowl
About thenightowl
  • Birthday 23/10/1958
3,690 profile views
thenightowl's Achievements
Engager
Engager (3/12)
0
  1. That is the worst case senerio, best one being, plumbing it into the existing system and it works on a thermo syphon principal. If not maybe a solar powered pump. It has too meet the needs for the bulk of the summer months I would of thought. Regards Peter
  2. Just found this, hope the link works, looks like the perfect device for heating water on the boat? Your thoughts? Peter Sorry trying to correct the fact I forgot the link! http://cgi.ebay.co.uk/swimming-pool-solar-..._Pools_Hot_Tubs
  3. I'm looking to point out that the fact he thinks he can retain the goods (given they belong to us) and apparently has no intention of giving a refund, amounts to theft! Either that or the small claims court? Either way, I'm sure it we put our two cases together, it will give it a little more weight. Regards Peter
  4. Hi Bear, Any luck trying to get a refund? I'm still trying to recover mine, it seems quite obvoius he is quite happy to hang onto it as well as the goods. Hope you have had better luck your end? Regards thenightowl
  5. Gibbo, When I've been near a supermarket overnight, I go in and place items that I need like water and milk and bury them deep in the freezer. Then return the next day and purchase them, always good to see the confused look at the checkout when they see frozen water/milk. Keeps the coolbag cold for 24 hours. Peter
  6. Hi Bear, Likewise, 3 weeks, false promises and still no sign of the money. Started with the promise of a full refund, once he had the goods, then a 15% restocking fee was implemented, plus postage costs. Regards
  7. Hi Bear, Just trying to highlight this topic, in the hope of warning others given the problems we have both had, would be pleased to hear if anyone has had any dealings with this company and actually got a good word?
  8. Hi Wendy, 64/64th's means you own the whole boat! (Or at least that was how it was explained to me). Apparently this is just the convention used in boating. I would imagine the 1/64th is wrong? Regards Peter
  9. I went for the B/W option for that reason, should aid vision both on TV and underwater, point taken re the I/R will see how it works with this setup? Peter Robin, That is what I thought and still do now its arrived, it is a bit heavy, but that should stop it going over the side? Just needs to be tested. It is certainly portable, together with the waterproof aspect would allow for it to go to the bow, should this be needed. The large silver object on the bottom, just seems to be a weight, so could take a pole instead. Peter
  10. It's just arrived, been looking at this on Maplin for a while. Self contained unit with 20m of cable. The unit has a 5 1/2 b/w camera, sits in a cover/sun shade. In the base is a rechargeable battery (12v dc, or 240 adapter), apparently 4 hrs use on a charge. Camera has night vision up to 7m. Quite a bulky unit, but comes with a carry case. Thought it would help given my access through weed hatch is a pain in the backside, so the prop does not get checked! Anyone interested Maplin Underwater CCTV Surveilance System Code N77FX. Cost £60 reduced by £5 if you use the money off vouchers. If I find my Rain-hat from the bottom of the Marina, that will be another £20 saved! Hope this is of interest to other like minded people. Regards Peter
  11. hmmm...I think its time you sold your soul to me? lol
  12. I bought one and sold it. Had the image been the same as you see on the internet (as they would have you believe) it would have been OK. They use compression software, so you end up with something less attractive, that did not work for me. Very fiddly to use, very good in principle. Maybe Mk 3 will be better. Maplin have them on display in some stores, so best have a look. Peter
  13. I bought on from Aldi the other week, £65. Basically the same set up as all the rest. Two things that were an improvement for me. Firstly comes with soft case (given the plastic one is very bulky). Secondly the base had a very large surface area, with no wind would be self supporting, attach magnetsto cope with wind, it hinged to allow various types fitting. POST/WALL even showed attached to a side of nb! Peter
  14. Thanks for that Alan, Sounds like I may have to revert to 'Plan A', and get a Shotgun! Peter
